Missing a bit of coolant - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By repalmer
  • 1 Post By HeavyAssault
post #1 of 9 Old 08-05-2019, 04:30 PM Thread Starter
wellcraft's Avatar
Quoted: 118 Post(s)
OK, guys, I have a question about coolant, the truck is an 07 with only 88k miles. The truck has a few upgrades blue spring kit, coolant filter, oil bypass system, straight exhaust, and few other things you can see in my sig, btw truck never been tuned. Right now there is a power loss but I'm working on it since its injector related.
The only issue is the degas bottle drinks coolant. When I do an oil change I check the coolant level and I have always had to fill it to the proper level when itís down but not much, never seen a leak. I did notice a bit of residue on the degas cap.
I did clean the EGR valve a few years ago and I believe it was a bit wet but back then I didn't know it was supposed to be dry. Will check that again tomorrow and see how it looks. I attached a picture of the degas cap that was replaced a few years ago and probably has less than 15k miles on it.
FWIW, every time I'm in a flat area I check my deltas, last time I did they were about 10 degrees difference if I remember correctly, but that was summer 2017 ago and I haven't used the truck much this past year.
I'm assuming the issue could be either the EGR or head gasket if its the EGR I believe I should be able to tell by looking at the EGR valve, but what about HG?
ID:	721473   Click image for larger version
07 f350 Dually tow boss, NUC delux oil bypass with Amsoil filter, IPR high flow coolant filter, blue spring, dummy plugs, stand pipes, Fabtech 6" lift kit with stealth shocks, Bilstein 5100 steering stabilizer, 4" MBRP turbo back exhaust, Edge Evolution with EGT sensor, PHP ficm programmer, BPD Ficm, BPD water pump, BPD 7.3 fan upgrade, BPD diesel aluminum fuel cap, OEM intercooler cac tube upgrade, 6.7 starter, 6.7 tailgate, Harley Davidson style headlights, color matched front grill, Bushwacker 2" front fender flares, Warn front hitch, custom front bumper, Ravelco anti theft system, Fumoto drain plug.
wellcraft is offline
post #2 of 9 Old 08-05-2019, 08:09 PM
Sock Puppet's Avatar
Quoted: 573 Post(s)
It could also just be a small leak that only shows up under normal pressure caused by thermal expansion (so, when it's warmed up and you're driving it). If you have a bypass filter with valves, take one loose from the filter head and use it to pressure up the cooling system until the cap relieves, then close the valve to leave it under pressure. Get out your flashlight and look everywhere on/around the engine, and lay underneath it. It may take a few moments to show up.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #3 of 9 Old 08-06-2019, 12:45 AM
repalmer's Avatar
Quoted: 608 Post(s)
The minimum line is where the maximum line should be. Looks like where your fluid is now is about perfect. I'd replace the car with an OEM.
Also, rig up an inline psi gauge to the degas bottle to check your coolant pressure
SparkyF250 likes this.
repalmer is offline
post #4 of 9 Old 08-06-2019, 12:50 AM
Jjorgis5569's Avatar
Quoted: 71 Post(s)
Talking
Well that would definitely fix it
Jjorgis5569 is offline
post #5 of 9 Old 08-06-2019, 12:57 AM
repalmer's Avatar
Quoted: 608 Post(s)
Yeah, that would fix the problem
Dang auto correct!!!
Everytime my phone updates software my text dictionary gets all screwed up. It's really starting to piss me off. Just right now I had to spell out piss because it got erased from my learned dictionary
Jjorgis5569 likes this.
repalmer is offline
post #6 of 9 Old 08-06-2019, 03:28 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 874 Post(s)
Feedback Score: 3 reviews
Well your sig line say: 07 f350 Dually tow boss, Fabtech 6" lift kit with stealth shocks,
Is your truck lifted???
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #7 of 9 Old 08-10-2019, 12:51 PM Thread Starter
wellcraft's Avatar
Quoted: 118 Post(s)
I spent some time under the truck and on the engine bay and found a pinhole sise in one of the hoses from the coolant filter so I will be replacing the hose for sure. I also notice the coolant filet canister was a bit wet, dried that out but never was it wet again so I need to keep monitoring that. I did remove the cap when it was at normal operating temperature and it had very little pressure. I replace the cap, maybe less than 12k miles ago with an oem.m I also removed the egr valve and it doesn't seem bad to me, what do you guys think?
Yes, the truck is lifted 6".
ID:	721625   Click image for larger version
ID:	721627   Click image for larger version
ID:	721629   Click image for larger version
ID:	721631   Click image for larger version
post #8 of 9 Old 08-10-2019, 12:52 PM Thread Starter
wellcraft's Avatar
Quoted: 118 Post(s)
Few more pics of the egr valve.
ID:	721635   Click image for larger version
ID:	721637   Click image for larger version
post #9 of 9 Old 08-11-2019, 02:26 AM
N.S.D.Q.
Quoted: 874 Post(s)
Trucks that are leveled or lifted are not showing the coolant level correctly due to the OEM rake angle is now gone. With consideration to your posted pic of the degas tank: Fill till the coolant is sitting at the MIN mark.
EGR valve seems fine/typical to me.
Sock Puppet likes this.
