Dually gearing? Coming from a SRW - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 15 Old 08-02-2019, 02:50 PM Thread Starter
Gaius's Avatar
Quoted: 73 Post(s)
Sold my SRW, 3.73 with 285s on it (34s). Gearing felt great, at 2k RPM I was around 74 mph.
This new dually has 4.10s and 245s (like 31-32 inches). Aside from just being overall lower, the gearing seems super high, 2k RPM is 63 MPH. Feels like I'm in 4th all the time.
Question is, will my fuel mileage suffer cranking along above 2k RPM? I regularly go 70 or more in Utah and Nevada. I know I can go to 255s (33s) but I was thinking of regearing it myself. Worth it?
Thanks!
ZMANN likes this.
Gaius is offline
post #2 of 15 Old 08-03-2019, 02:56 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 761 Post(s)
Feedback Score: 3 reviews
Keep the gears, get taller tires. It's not difficult to run 35's and get the RPMs where you want them.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 15 Old 08-03-2019, 06:00 AM Thread Starter
Gaius's Avatar
Quoted: 73 Post(s)
On a dually? For tires that big I'd need funky wheel spacers or different wheels. Gears are cheaper than wheels.
Gaius is offline
post #4 of 15 Old 08-03-2019, 06:52 AM
ZMANN's Avatar
Quoted: 3853 Post(s)
Have you ever set up gears ? if so you know the drill dial indicators , in lb torque wrench , gear contact paste , experience over book is a key IMO
plus your pulling axles out to do this so you may be looking at more parts specially if 4x4
if not i would hand the job over to a shop and pay the extra for them to supply the gears so the whole deal is under their warranty
personally i like big tires ;-) good luck and keep us posted
SparkyF250 likes this.
6.0 flush pdf
ZMANN is offline
post #5 of 15 Old 08-03-2019, 07:09 AM
SparkyF250's Avatar
Quoted: 3136 Post(s)
Garage
To answer your question, Yes your mileage will suffer when you tach over 2000, that seems to be the magic number, at least on my truck. Temps will be different then what you're used too as well.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
1991 F350 4x4, 7.3 IDI Flatbed, 5 speed...sold
2008 F250 SCLB 6.4...Sold
SparkyF250 is offline
The Following User Says Thank You to SparkyF250 For This Useful Post:
Gaius (08-03-2019)
post #6 of 15 Old 08-03-2019, 07:12 AM Thread Starter
Gaius's Avatar
Quoted: 73 Post(s)
Yes, have set up lots of gears. No problem except for new parts. D80 gears aren't cheap, but cheaper than 6 wheels and 6 tires.
Sent from my Pixel 3 XL using Tapatalk
ZMANN likes this.
Gaius is offline
post #7 of 15 Old 08-03-2019, 07:14 AM Thread Starter
Gaius's Avatar
Quoted: 73 Post(s)
Bummer. I like the power, but the cruise RPM feels all wonky. I'm betting I get used to it, but I don't want any worse mileage. A few MPG sure adds up on long trips.
Gaius is offline
post #8 of 15 Old 08-03-2019, 07:29 AM
SparkyF250's Avatar
Garage
Not sure what OEM gears cost, but here's good deal on some Yukon's. Pretty sure the Dana uses shims instead of a crush sleeve like the Sterling so it should be a little easier to set up.
https://www.amazon.com/Yukon-D80-373...omotive&sr=1-1
Sparky
post #9 of 15 Old 08-04-2019, 06:10 AM Thread Starter
Gaius's Avatar
Quoted: 73 Post(s)
Thanks. I'm both a Revolution and Yukon dealer. I also use a Crush sleeve eliminator kit when I use the Sterlings on a build (same one as most all Ford axles), but for the tow rig I would leave the crush sleeve. It's a lot faster for me actually.
Crush Sleeve For Model 20, Ford 10.25", 10.5", 7.5", 8.8", 9 3/8", 9"
https://www.yukongear.com/productdet...px?ProdID=8273
Gaius is offline
The Following 2 Users Say Thank You to Gaius For This Useful Post:
ZMANN (08-04-2019)
post #10 of 15 Old 08-04-2019, 07:00 AM
ZMANN's Avatar
once you have the crush sleeve set isn't it as simple as removing it and replacing with a properly sized eliminator and thereby avoiding future issues ?
6.0 flush pdf
ZMANN is offline
