Engine Oil Temp vs Engine Coolant temp - Ford Powerstroke Diesel Forum
 24Likes
post #1 of 16 Old 07-28-2019, 04:27 PM Thread Starter
Quoted: 10 Post(s)
So I finally got an Edge CTS2 monitor setup on my 03 F350 6.0 Powerstroke. Running around town my EOT is running around 226 and highway driving it’s getting up to 246 and my coolant temps are 188- 190 .
Truck was a 1 owner with 103k miles always dealer maintained. I’m assuming my oil cooler is plugged and looks like I’m gearing up for an EGR delete and new oil cooler.
Do you think flushing the system will help this 56 difference in temps or not even bother flushing and just do the oil cooler replacement and EGR delete? From what I understand temperatures should not differ by more than 25.
50dan is offline
post #2 of 16 Old 07-28-2019, 04:31 PM
Quoted: 456 Post(s)
The limit is 15 degrees.
Flush it well and change to an EC-1 rated ELC coolant (ie get rid of the Ford Gold).
Then you still may need to put in a new OEM oil cooler - but before doing that you need to get the system as clean as possible w/ the right coolant.
fordsvtparts and SparkyF250 like this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 16 Old 07-28-2019, 05:53 PM Thread Starter
Quoted: 10 Post(s)
I’ll start by doing this and see what happens thanks Bismic
50dan is offline
post #4 of 16 Old 07-28-2019, 06:52 PM
Quoted: 467 Post(s)
Garage
Check the EOT and ECT after the engine has been off overnight or longer to see if they read the same temperature -- may just be a sensor problem -- the sensors are the same, could also swap them around to see if the temps follow
HeavyAssault and Tobydog007 like this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #5 of 16 Old 07-28-2019, 07:05 PM
Tobydog007's Avatar
Quoted: 37 Post(s)
If you end up changing the oil cooler, make sure you also flush the radiator as well... My radiator was flaking off trash no matter how much I flushed it and I ended up replacing it. The price of a new radiator is cheap in the grand scheme of you situation. Been there done all of that and got a hell of an education the hard way.. My temps are now 3-5 delta around town on on the highway and 8-11 towing... I am very happy with mine now, but I had to go through the pain... LOL
Dan
bismic and Hydro like this.
Tobydog007 is offline
post #6 of 16 Old 07-29-2019, 09:39 PM
Gaius's Avatar
Quoted: 78 Post(s)
With temps that high just highway driving, flushing will not fix it enough. I would replace the cooler.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #7 of 16 Old 07-30-2019, 05:46 PM
Quoted: 69 Post(s)
A good backflush will likely improve the situation, but yeah, I'd expect needing an oil cooler replacement.
Doward is offline
post #8 of 16 Old 07-30-2019, 05:58 PM
SparkyF250's Avatar
Quoted: 3346 Post(s)
Garage
Just flush it real good before you tear it down, you don't want to clog the new one. And if it's going back in the valley don't get a cheap aftermarket cooler. New OEM is about $300 at WBL @fordsvtparts can hook you up.
BTW open both block plugs when you flush it, a Fumoto F108N behind the starter makes it so you only have to drop the starter once.
Cat EC-1 spec ELC when you reassemble Cat, Rotella, Delo, and Texaco are all OK. Don't get 50/50, you'll need concentrate. And when you clean the oil reservoir under the oil cooler use microfiber rags so you don't leave lint behind. You don't want to have to pull the IPR when you're done cause you let lint get thru.
DTR has a good video of a BPD EGR cooler and OEM oil cooler job. Just do your delete and ignore the EGR replacement. even if you've been in there before it's handy reference.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
The Following User Says Thank You to SparkyF250 For This Useful Post:
fordsvtparts (07-30-2019)
post #9 of 16 Old 07-30-2019, 08:52 PM
fordsvtparts's Avatar
Quoted: 144 Post(s)
Lot's of good advice here!
https://parts.autonationfordwhitebea...it-3c3z6a642ca
SparkyF250 and Tobydog007 like this.
We are Autonation Ford of White Bear Lake selling all OEM Ford parts at employee prices (formerly Tousley)
Call us at 1-800-328-9552 (be sure to mention this website when calling)
OR check out our website
I'll meet or or beat any price on OEM parts
fordsvtparts is offline
The Following User Says Thank You to fordsvtparts For This Useful Post:
SparkyF250 (07-30-2019)
post #10 of 16 Old 07-31-2019, 03:05 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 920 Post(s)
Feedback Score: 3 reviews
If your ECT doesn't exceed 190* at any driving condition........you need a tstat first.
After all that oil cooler work to have the same delta "problem" would be a headache cause spending more money than you need to could have been avoided.
Tobydog007 and Jjorgis5569 like this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
