Should I Install These Injectors? - Page 4 - Ford Powerstroke Diesel Forum
 33Likes
post #31 of 45 Old 08-02-2019, 07:56 PM Thread Starter
Sock Puppet's Avatar
Quoted: 554 Post(s)
Quick question on this rocker/bridge on cyl. 8. I've read that this isn't uncommon, but thought I'd ask if it's cause for concern. @ZMANN @Hydro @bismic @G8orFord I see the dirt that fell on the spring and will get that vacuumed out.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #32 of 45 Old 08-02-2019, 11:38 PM Thread Starter
Quoted: 554 Post(s)
Well, I looked at enough pics online to determine it's pretty common and not something to be overly concerned about. Driver's side bank has new injectors and is reassembled except for the FICM.
post #33 of 45 Old 08-03-2019, 05:04 AM
G8orFord's Avatar
Quoted: 2518 Post(s)
Garage
Yeah, I wouldn't worry about that too much. It looks like a casting flaw. I'm a little OCD about stuff like that and would probably had replaced it if given the chance, but the logic in me says it's really not necessary.
Sock Puppet, voodooridr and Hydro like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #34 of 45 Old 08-03-2019, 06:55 AM
ZMANN's Avatar
Quoted: 3899 Post(s)
it is common and as noted by your google search
many have the same concern about a lot of cast parts
they sure left the rough but it's just aesthetics in this application
Sock Puppet and Hydro like this.
6.0 flush pdf
ZMANN is offline
post #35 of 45 Old 08-03-2019, 07:28 AM Thread Starter
Quoted: 554 Post(s)
As requested, here are a few pics from the Motorcraft remans from the Ford dealer:
post #36 of 45 Old 08-03-2019, 05:44 PM
ZMANN's Avatar
take off the condom before insertion ?
Hydro likes this.
6.0 flush pdf
ZMANN is offline
post #37 of 45 Old 08-03-2019, 05:44 PM
ZMANN's Avatar
i will report myself for that comment
6.0 flush pdf
ZMANN is offline
post #38 of 45 Old 08-03-2019, 05:53 PM Thread Starter
Quoted: 554 Post(s)
Crap...guess I need to take it back apart. The instructions said nothing about removing them before installation!!!
post #39 of 45 Old 08-03-2019, 05:54 PM Thread Starter
Quoted: 554 Post(s)
Just kidding.
Had a family event today, so I'll get it wrapped up tomorrow.
post #40 of 45 Old 08-03-2019, 05:55 PM Thread Starter
Quoted: 554 Post(s)
Heck, I'm just glad the new ones from the Ford house weren't all beat to hell like the first set I got
voodooridr likes this.
