Miss / Sputter WOT Up Hills While Towing - Page 2 - Ford Powerstroke Diesel Forum
 2Likes
post #11 of 13 Old 07-29-2019, 07:36 AM
Quoted: 514 Post(s)
I think you still have injector issues in addition to a cooling problem.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #12 of 13 Old 07-29-2019, 05:34 PM
Quoted: 22 Post(s)
Lots of good comments from everyone, as usual.
My thoughts;
my truck (non excursion) runs low 220ís while towing. It stays there I donít sweat it too much. But maybe I should also look in to the things the others mentioned.
Fuel delivery; sounds like there is some issue there. Do you monitor fuel pressure ? If not you should. Do you have a speed limiter ? If so I would turn it up to 180mph and see if you can run it out of fuel during a WOT run. I have a weird suspicion you are not producing adequate FP.
Larry Grogan is offline
post #13 of 13 Old 07-29-2019, 07:31 PM
doubleslottedflaps's Avatar
Quoted: 190 Post(s)
That sounds like you need points , condenser ,plugs, rotor , cap and possibly a set a Y R's.
Hydro likes this.
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
