Battery idiot light and high charge voltage - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By TooManyToys
post #1 of 5 Old 07-20-2019, 03:39 AM Thread Starter
OK, I have a 2005 E350 Superduty Van with a 6.0. Single alternator.
Few days ago in hot weather, a battery shaped idiot light in the dash lit and the scan gauge showed charging almost a volt higher than normal. Now the charge fluctuates from 13.5-14.4v, (it normally fluctuates between 12.4-13.3). When it was cool the next morning I started the van and same thing, battery light and high charge voltage. The alternator was replaced last summer, and has been fine, till this.
Any one experience anything like this before? Any suggestions?
Thanks in advance for the valuable advice always provided on these forums.
gene
FourCeesuns is offline
post #2 of 5 Old 07-20-2019, 04:00 AM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1665 Post(s)
Garage
I'm going to head straight for the alternators voltage regulators got a little problem. But I also would be sure to clean all your battery cable connections and apply some grease on terminals too.
Take alt back and install a new one.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3” CAC Pipes & CSF 7106 I.C.
4” Diamond Eye SS Exh System
W/ Magnaflow & Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #3 of 5 Old 07-20-2019, 04:11 AM
Quoted: 12 Post(s)
The place you bought the alt from should also be able to test it once you get it off.
Sent from my LG-LS993 using Tapatalk
5J's is offline
post #4 of 5 Old 07-20-2019, 01:30 PM
BTL
BTL's Avatar
Quoted: 192 Post(s)
Before you get rid of your alternator, what type of batteries do you have? Odyssey (AGM)? From what I understand reading the “Odyssey Technical Manual” a charging voltage of 14.4V-14.7V is optimal and a maintenance trickle charge voltage of 13.5V-13.8V is recommenced for maximum battery life. My Voltage on my scan gauge 2 varies from a low of 13.9 to a high of 14.7. That is not including before, during or after starting. I have never seen a battery idiot light indicator on my dash.
BTL.
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4” SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8” draw tube
BTL is offline
post #5 of 5 Old 07-20-2019, 01:54 PM
Quoted: 116 Post(s)
The typical regulator at battery will start off with a goal of 14.4, but has a thermistor in the regulator to bring that down to 13.6 to 13.8 to prevent damage to the standard batteries at high underhood temps. It hasn’t been until recently that Ford is adopting AGM and altering the regulator for that battery style.
While the cluster battery light is normally on for a low voltage alternator output, it will also come on if a diode in the alternator is bad and outputs a wider range of A/C current. Meters Switched on DC are dampened enough to not show that, but switching over to A/C can. Some have seen a voltage on OBD2 monitors over 15 with a bad diode.
This guys not too bad.
BTL and Hydro like this.
TooManyToys is online now
