Bypass filter change interval - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 15 Old 07-19-2019, 03:39 PM Thread Starter
Quoted: 7 Post(s)
I recently flushed my truck's coolant of the gold coolant and filled with ELC and a bypass filter. I have seen a post or two of folks changing the filter every three months. My truck is not a daily driver and I was hoping someone here might be able to give me an idea of how often to change the filter more on a mileage basis.
Dauntless1971 is offline
post #2 of 15 Old 07-19-2019, 04:35 PM
Quoted: 323 Post(s)
Garage
Once a year, or when the filter and lines do not feel equally hot anymore -- I think 3 months is overkill unless at the start when the filter unit is first installed -- cutting the filter open will let you see how much junk it is capturing and give an idea of when to change
Be sure and use the filters that do not have the additive inside -- I don't have part numbers but Wix, Fleet Guard, Napa all make filters that will fit
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 15 Old 07-19-2019, 06:51 PM
Quoted: 2 Post(s)
I was advised 10,000 miles by the International parts dealer where I bought my last filter, for what it's worth
dh3415 is offline
post #4 of 15 Old 07-19-2019, 08:06 PM
ZMANN's Avatar
Quoted: 3883 Post(s)
not worth much since he is pulling that out of his A##
6.0's never came with a byapss coolant filter so there is no spec
the 7.3 had one in certain applications but it is not a comparable setup to the 6.0
I agree with Hydro
cutting them open is the only way to tell whats going on
i would cut the first one open after a few weeks if it is loaded I would do the same until it cleared up
if it is pretty clear on the first inspection I would go to 6 months or a year ( cost you about 11 bucks each time )
if you're running gold coolant i may do every 3 months
mhatlen likes this.
6.0 flush pdf
ZMANN is offline
post #5 of 15 Old 07-19-2019, 09:30 PM
Quoted: 12 Post(s)
I've decided to do mine every oil change just to keep it simple. I did the first one at 500 and cut the old filter open to inspect it and I was actually surprised. This is what I found.
Sent from my LG-LS993 using Tapatalk
5J's is offline
post #6 of 15 Old 07-20-2019, 03:24 AM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1679 Post(s)
Garage
I think you should change it right now to a IPR full flowing 3/4"filter. But that's not exactly what your asking about.
So I'll start again: the guys are correct that you should look at it quite soon the first time to see if you still have materials in cooling system after you flushed. 500-1,000 miles would be as far as I'd go first time.
ZMANN zip it. Jackals' a time or two in a lifetime can feel the sun hit their Lilly white azz that in turn spurs kicking out a game winning gadget.
500-1000 miles. Yup... I'm out of here, boy do I need to sleep better and stop kicking cans when I don't.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #7 of 15 Old 07-20-2019, 12:53 PM
ZMANN's Avatar
if you have air tools I would suggest an air chisel to open the filter for a clean debris free cut
the one on the far left
6.0 flush pdf
ZMANN is offline
post #8 of 15 Old 07-20-2019, 01:00 PM
ZMANN's Avatar
@mhatlen that ding dong did not invent the filter he uses nor the concept just machined a manifold for the 6.0
pure power and others has sold these for a long time
go find an oil filter mount of the proper thread and wala u have 80% of his kit the other 20% of that kit won't work for us running BPD cooelrs anyway
"sunshine on his azz " would require coming his seeing the light wouldn't it ;-)
mhatlen likes this.
6.0 flush pdf
ZMANN is offline
post #9 of 15 Old 07-20-2019, 06:38 PM
mhatlen's Avatar
Garage
Ok step on that brake pedal Clark Kent slow it down just a whisker.
I made no claim he invented the internet or the tampon or even the pivot man position for a circle je…...…..never mind I think its his patent too. Kicking out a product may insinuate creation of the said item. Hypothetically or possibly allegedly creating something new that brings a said Creator of a product with proper data showing a said individual applied for its patent of said item. That being said that can by all means be two or even 10 items others have created as well as manufacture has no influence.
Whats critical is the said unit/individual putz skitz a accurate description of the dweeb also carries no value here. But AS LONG AS ITS HIS IDEAS that blooms into his new creation then that said individual bacteria weasel dudes new item will be patented and Alfalfa receives legal ownership of it.
At least theoretically, Are we still picking up my line of reason and a bit of its order on the matter. Like all things going to market there's so many factors that can influence these new and different *****ara thingy magigers on their maiden voyage to the free market and is what controls success or failure in the single wide again.
But if the sun ones dairy aire just right and its purpose exceeds all others the possibility of severe injury exists once money from Heaven begins reaching downpour levels.
What a bunch of hogwash. I know guys a Loon, the strange little loon markets the only coolant filter worth putting money down on the table for.
Goodnight damnit this hurt my own self respect.
Forgot to mention your splendid posts though short on factors dictating who is Big Boy of: ideas/pipe dreams/coolant filters/gravity free crappers from idea to their climax. Splendid still all the same. Better then this crap.
CAT EC-1 coolant
mhatlen is offline
post #10 of 15 Old 07-20-2019, 06:58 PM
ZMANN's Avatar
wait what ? You lost me at "self respect" even if it was the last words in your rant
LOL ... EDIT was last words until you edited your post
kisses
mhatlen likes this.
6.0 flush pdf
ZMANN is offline
