Blower motor rotation direction - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-17-2019, 12:12 PM Thread Starter
Quoted: 8 Post(s)
I changed out my blower motor last year due to the air flow being weak and nothing changed. Everything on my ac system is new except the evap housing got beat up and cracked in a few spots. I’ve never been able to feel my ac past a foot from the vents. I was reading about aftermarket blowers can be wired differently. Just curious about the correct rotation of our blower. I have a 05 f250 6.0
Druben is offline
post #2 of 5 Old 07-17-2019, 01:03 PM
a known holder of grudges
SixStringMadness's Avatar
Quoted: 17 Post(s)
Garage
have you replaced the fan speed resistor pack - it sits right there under the hood in the blower motor.
I drive a Powerstroke, its not stock.
I put hard earned money into it
SixStringMadness is offline
post #3 of 5 Old 07-17-2019, 02:19 PM Thread Starter
Quoted: 8 Post(s)
I sure have. All my speed settings work perfectly also. Just doesn’t blow worth a crap
Druben is offline
post #4 of 5 Old 07-17-2019, 06:37 PM
doubleslottedflaps's Avatar
Quoted: 162 Post(s)
my 02 and 06 never blew good. i put new motorcraft motors, wheels and gaskets in both with no change. 2 friends have 02's that dont blow good. My 01 blows really good and has the original motor. its just the way they are....C H E A P a/c units.
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #5 of 5 Old 07-17-2019, 06:59 PM
Quoted: 304 Post(s)
Garage
You sure there isn't a pile of leaves or a mouse nest in the heater core? -- my 06 Lariat blows out the vents pretty well
Not sure if the motor polarity can be reversed, but if you want to check, pull the fan motor -- then power it up and note the rotation -- the fan cage should rotate with the outer part of the fins in the forward direction "/" ...ok not a good diagram, but you should get the jist
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
