Egr delete symptoms 2004 6.0! - Ford Powerstroke Diesel Forum
 9Likes
post #1 of 16 Old 07-16-2019, 04:15 PM Thread Starter
El Gallo's Avatar
Quoted: 19 Post(s)
Garage
I have an 04 6.0. I’m wondering if there are any side effects to having an egr delete. My tuner allowed me to clear egr codes. I have read a lot about newer trucks, but in an 04, what actually happens when an egr is removed?? Thanks!
2004(.5) F250 XLT
arp studs
egr delete
egr cooler delete
Powermax stage 2
155/stock injectors
mishimoto coolant filter
El Gallo is offline
post #2 of 16 Old 07-16-2019, 06:06 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 592 Post(s)
Feedback Score: 11 reviews
When you remove the egr cooler you prevent exhaust gas from being put into the intake.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #3 of 16 Old 07-16-2019, 06:32 PM Thread Starter
El Gallo's Avatar
Quoted: 19 Post(s)
Garage
Yes that I know. To be more specific: cooling fan function? VGT operation? Any “side effects”?
2004(.5) F250 XLT
arp studs
egr delete
egr cooler delete
Powermax stage 2
155/stock injectors
El Gallo is offline
post #4 of 16 Old 07-16-2019, 08:04 PM
drivininidaho's Avatar
Quoted: 96 Post(s)
I've had mine done for about 4 years or so. Havent noticed anything wrong with doing it. But I'm still figuring out other small quirks as well. But I've been lazy and havent driven truck much
Sent from my SM-G955U using Tapatalk
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #5 of 16 Old 07-17-2019, 02:12 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 756 Post(s)
Feedback Score: 3 reviews
Doesn't the EGR valve sense flow into the intake?? So that would cause the system to "see" the EGR cooler is not functioning properly (read: clogged) and throw a code...right?
So that's going to cause more than just a few things to happen while driving.
Officially The Biggest Midget In The Game
HeavyAssault is online now
post #6 of 16 Old 07-17-2019, 07:01 AM
BBBRRRRRTTTTT
Quoted: 592 Post(s)
it only senses egr flow.
remove the cooler and keep the valve plugged in and the truck will operate correctly.
john galt and El Gallo like this.
post #7 of 16 Old 07-17-2019, 02:37 PM Thread Starter
El Gallo's Avatar
Quoted: 19 Post(s)
Garage
Thank you! That’s exactly the answer that I was looking for.
2004(.5) F250 XLT
arp studs
egr delete
egr cooler delete
Powermax stage 2
155/stock injectors
El Gallo is offline
post #8 of 16 Old 07-18-2019, 05:46 PM
1892FF1785's Avatar
Quoted: 3 Post(s)
I've had my '04 deleted since early 2012. No i did not leave my valve plugged in. I turned off my egr with my SCT programmer. The truck stores two different codes for the egr but DOES NOT turn the MIL on. No adverse effects. The truck ran fine. Replaced my '04 with an '05 after I backed into a tree and bent my frame while plowing this past January. I switched all my stuff over to the '05 and I still get the same 2 egr fault codes but no MIL on the dash.
On a different note, when I purchased the '05 I didn't realized how many differences there were between the two trucks until I swapped the motor from my '04 to the '05. But that can be a whole different thread.
1892FF1785 is offline
post #9 of 16 Old 07-18-2019, 05:59 PM
Quoted: 6 Post(s)
you will run less boot usually.
also, matt robinson from gearheads told me they were seeing better MPG of 6.0's that still had EGR'S vs deletes.
bench
El Gallo likes this.
2005 excursion 6.0
studded/deleted
bpd oil cooler/water pump/radiator
gearhead tuning
4" exhaust/S&B intake
4" lift toyo 35's
2015 f350 6.7
studded/deleted
spartan tuning
4" lift toyo 35's
benchmstr is offline
post #10 of 16 Old 07-20-2019, 04:47 AM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1654 Post(s)
Garage
Ok yes you will loose a small amount of lower rpm boost without the EGR system pumping HOT high pressure exhaust into the cool intake manifold. It's not pretty what a EGR system does to the 6.0 Power Stroke engine. When engines running at low speeds coking is at its worst and can seriously reduce the intake porting over time.
A EGR systems benefit comes from lowering nox by trading oxygen for inert gases that cannot burn again throughout combustion cycles lowering the amount of molecules exiting from combustion cycles. So your dropping cylinder temperature to lower the amount of molecules becoming nox from the burn.
I see it as a perfect way to cheat and lower nox output. They could likely do much better by refining the fuel more. Not sure how well it could improve on diesel engines but huge gains of lower emissions come from 100 octane and higher fuel.
The likelihood of seeing 100 octane again at the pump is extremely high. It's by far the easiest way the US can meet the carbon output reduction targets given at Paris Agreement regarding worldwide Clean Air Act set for 2025. lol maybe Theres a timeframe??
I'm a dumb pipe fitter who think the French are pussies and hair twirling dreamer's. I didn't go But this cheap to refine crappy fuel @ 87 & 91 octane is pretty inline for being another stupid thing done that's come at one hell of a high price. Yea imagine that in the long run.....cheap fuel made oil companies crazy higher profits and that crap dumped twice the garbage in our atmosphere and oceans.
Oooops in a nutshell screw the EGR system. lol
john galt, voodooridr and El Gallo like this.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/ Magnaflow & Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
