Tuner and monitor - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Chris
  • 1 Post By powerstrokeshellback
post #1 of 8 Old 07-15-2019, 09:28 PM Thread Starter
cmayeski51@gmail.com's Avatar
Quoted: 3 Post(s)
Tuner and monitor
I am looking to get a tuner/monitor. I am unsure of what to get. I've been mentioned some of the SCT tuners. Any suggestions would be appreciated.
post #2 of 8 Old 07-15-2019, 09:33 PM
Mr. Crossthread
waggonerj's Avatar
Quoted: 1907 Post(s)
Garage
Get an sct product. Whichever one you pick is all preference, same goes for tuning. You'll have to try a few companies out to see what matches your driving style.
Sent from my Pixel 2 XL using Tapatalk
Justin
2005 F250 300,000 miles
ARP Studs - OEM Gaskets - Machined Heads - EGR Delete - 4" Straight Pipe Axle Dump - MBRP Up-pipes - Holder's 175/Stock Injectors - KC Stage 2 63.5mm - Custom Water/Meth Injection - Beans Diesel Sump - PHP FICM Tuner - SCT X4 - TSD Tunes - Riff Raff Boots and Clamps - Coolant Filter - Blue Spring - CCV Reroute - Custom Big 3 Upgrade - Viper Remote Start - Aluminum Radiator
Check out MPA, those guys are pretty decent
TPB!
waggonerj is offline
post #3 of 8 Old 07-16-2019, 04:20 AM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
I went with the SCTX4 tuner and an Edge Insight CTS2 for monitoring. Couldn't be happier with the setup.
jokester00 likes this.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #4 of 8 Old 07-16-2019, 05:53 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 609 Post(s)
Feedback Score: 11 reviews
i have a cts 2 insight for sale if youre interested.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #5 of 8 Old 07-18-2019, 04:58 PM
Quoted: 11 Post(s)
I might be. What are you asking for it?
Steve
Sent from my SM-N950U using Tapatalk
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
"The Little Blue Spring"
Full coolant flush - now running CAT ELC
New oil cooler, standpipes & dummy plugs, 6.4 Banjo bolts, STC fittings
EGR Delete
SCT Tuner running "Looney"
Edge Insight with EAS-EGT
Rotella T-6 5W40 and Rev-X
4x4ff is offline
post #6 of 8 Old 07-18-2019, 05:09 PM
wiredgeorge's Avatar
Quoted: 25 Post(s)
What are you planning on doing with the tuner? Also, put your truck in your signature as it will help zero in answers a bit. I have an SCT X4 tuner and used it to add a stock SCT 50 hp towing tune and kill the EGR CEL which has been deleted.
2006 Ford F-350 6.0L Auto CC 4WD LB
2002 Keystone Cougar 278EFS
2006 GL1800 Roadsmith trike
Mico TX
wiredgeorge is offline
post #7 of 8 Old 07-18-2019, 06:37 PM
BBBRRRRRTTTTT
Quoted: 609 Post(s)
Steve
https://www.powerstroke.org/forum/pe...5-cts-2-a.html
post #8 of 8 Old 07-29-2019, 12:17 PM
F250SuperStealth's Avatar
Quoted: 17 Post(s)
Garage
With the release of the SCT GTX, there's not much reason to go with the x4+edge cts2 setup any more. The GTX is a good monitor and tuner in one package.
2005 F250 Harley Davidson CCSB
Southeast Cylinder Heads with O-Rings
A1 Technologies H-11 Head Studs
Fel-Pro Headgaskets
River City Diesel Pushrods
Bulletproof Diesel Oil Cooler Relocate Kit
Bulletproof Diesel Billet Water Pump
PowerMax Turbo with KC Turbo's Billet Wheel
IPR Coolant Filter
SCT GTX Monitor/Tuner
Gearhead SRL+ Tune
PHP Atlas 40 FICM Tune
Autometer SPEK-Pro gauges
4" Magnaflow Exhaust
F250SuperStealth is offline
