Average boost pressures - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 15 Old 07-15-2019, 08:55 AM Thread Starter
Pstroker890's Avatar
Iím looking for average boost pressures for a 2005 f250 Iím averaging 3-4 at 65 mph at 2 k and full wot 17psi just curious what others are experiencing
Pstroker890 is offline
post #2 of 15 Old 07-15-2019, 10:04 AM
G8orFord's Avatar
Quoted: 2565 Post(s)
Garage
Your 65 mph cruise pressure is probably about right, maybe slightly low, but that's a little relative. A WOT run should get you about 26-30 psi. I'd imagine your turbo unison ring is stuck or you have a boost leak.
Qholic, SparkyF250, BTL and 1 others like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #3 of 15 Old 07-15-2019, 11:42 AM
BTL
BTL's Avatar
Quoted: 201 Post(s)
My 65mph boost is low like yours at about 1900rpm, WOT hits 30+boost but I have a stage KC stage 2 plus other supporting mods.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4Ē SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8Ē draw tube
BTL is offline
post #4 of 15 Old 07-15-2019, 11:43 AM
partyman97_3's Avatar
Quoted: 895 Post(s)
Garage
I get about 22 or 23 with big red at wot. But I know I have a small air leak somewhere.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #5 of 15 Old 07-16-2019, 04:24 AM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
I see about 28 at WOT but I have exhaust manifold leaks on both sides. Plan on doing gaskets sometime in the next few months.
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #6 of 15 Old 07-16-2019, 06:19 AM
Fummins Mod
junior125's Avatar
Quoted: 2220 Post(s)
Garage
note for those with mostly stock trucks, depending on the strategy will vary the amount of boost
especially is tuned, it will vary tuner to tuner
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #7 of 15 Old 07-16-2019, 07:24 AM
jokester00's Avatar
Quoted: 484 Post(s)
Garage
I'm tuned with PHP's 80HP DD on the PCM with the Atlas 40 FICM tune. I will usually see 28-29 at WOT and ~7-9 at 65MPH.
However, like @junior125 said, your boost will vary depending on the tune, tuner, mods, etc.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #8 of 15 Old 07-16-2019, 08:54 AM
Quoted: 36 Post(s)
I have no leaks I am aware of. I had it smoke tested just this weekend so I'm sure that at least cold it is not leaking. Maybe I should try on a hot engine next. My truck always topped at 24PSI pulling a camper uphill @ 5-7k ft altitude if that matters. It does the same on stock tune or canned SCT 50HP tow tune.
GusCO is offline
post #9 of 15 Old 07-16-2019, 12:21 PM
ChrisSki's Avatar
Quoted: 573 Post(s)
With my WOT run, I usually see 20 PSI going on to the highway from 0 to 75, but can reach 26 PSI if circumstances are right. Only real mod I have for exhaust is a BD manifold, and that does not add or detract anything. I have stock injectors and a stock turbo. Prior to some work, I sued to get 26 PSI consistently.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #10 of 15 Old 07-16-2019, 07:59 PM
Quoted: 5 Post(s)
Garage
I think I'm developing 15 to 17 psi at WOT from a stop after a few moments off the line, I assumed that was good at 4500 feet elevation. Completely stock engine. After reading these post maybe my assumption is wrong. Is my boost low? I do have leaks at the up pipe connections to wye adapter and have ordered IH bellowed up pipe kit and plan to install this weekend along with EBPV delete.
