6.0 frame fuel pump - Ford Powerstroke Diesel Forum
 14Likes
post #1 of 11 Old 07-10-2019, 04:16 PM Thread Starter
deltabygod's Avatar
Quoted: 2 Post(s)
6.0 frame fuel pump
So back in Feb i had a motor an a bunch of work done to my truck by a "shop". I wont get into that right now. While looking at some possible land i want to buy, the truck acted like it ran out of fuel. After cycling the key a few times i noticed i could not hear the fuel pump. After crawling under the truck i see that the pump is not my 2004 excursion fuel pump. The shop chopped the power wires to the fuel pump an the wires pulled out of the plug. So after a long story reaches my question. Do later year fuel pumps have different plugs? What would have been the point to cut up my wiring? And i think the current pump is a 2006 or 2007 pump, guessing, is there a benefit over later year pumps over say a 2004? Thanks alot guys.
ID:	720753   Click image for larger version
deltabygod is offline
post #2 of 11 Old 07-10-2019, 08:43 PM
jokester00's Avatar
Quoted: 411 Post(s)
Garage
If I remember correctly, they all use the same HFCM, however, certain model years needed a different harness adapter to make the wiring work correctly.
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
post #3 of 11 Old 07-11-2019, 05:53 AM
voodooridr's Avatar
Quoted: 889 Post(s)
The replacement pumps eliminated the fuel heater so you'll need the updated harness
Sent from my SM-G960U using Tapatalk
jokester00 and Hydro like this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #4 of 11 Old 07-11-2019, 09:27 AM
Heavy_GD's Avatar
Quoted: 3092 Post(s)
Garage
Feedback Score: 4 reviews
solid chop work, not even a water proof connector.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #5 of 11 Old 07-11-2019, 09:40 AM
djmaguire's Avatar
Quoted: 1571 Post(s)
Garage
Let's hope that they never discover wire nuts.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #6 of 11 Old 07-11-2019, 09:43 AM
Heavy_GD's Avatar
Garage
They only use those for the high end work.
GD
Heavy_GD is offline
post #7 of 11 Old 07-11-2019, 05:57 PM Thread Starter
deltabygod's Avatar
Quoted: 2 Post(s)
Ya less than impressed is an understatment. I am not happy about losing the fuel heater either as i also live in northern Wisconsin where it tends to get colds as a witchs t*t! So was there any benefit to this shop doing this? My 04 pump was working very well as it had a brand new Racor pump in it. I dont understand why. Also how do i track down which connector they used so i can fix this awsome wireing nightmare?
post #8 of 11 Old 07-14-2019, 05:03 PM Thread Starter
deltabygod's Avatar
Quoted: 2 Post(s)
Any advice on this?
post #9 of 11 Old 07-14-2019, 05:24 PM
partyman97_3's Avatar
Quoted: 869 Post(s)
Garage
Are you looking for the pigtail.
https://www.riffraffdiesel.com/motor...pigtail-03-05/
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #10 of 11 Old 07-15-2019, 09:31 AM Thread Starter
deltabygod's Avatar
Quoted: 2 Post(s)
Thank you i think that is exactly what i need to fix my problem.
