Blue spring up grade Vs Fuel regulator - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 15 Old 07-10-2019, 11:52 AM Thread Starter
twood71's Avatar
Quoted: 60 Post(s)
Does the blue spring upgrade on the pump affect the fuel regulator?
I'm expecting you would have to re-adjust your fuel regulator after installing the blue spring upgrade correct?
twood71 is offline
post #2 of 15 Old 07-10-2019, 12:12 PM
Thesoulless's Avatar
Quoted: 10 Post(s)
Garage
The "blue spring" is an update to the fuel pressure regulator on the secondary fuel filter on top of the engine, the spring is the adjustment. Unless you're talking about updating something different, like a regulated return system, etc.
john galt and Hydro like this.
Thesoulless is offline
post #3 of 15 Old 07-10-2019, 12:28 PM Thread Starter
twood71's Avatar
Quoted: 60 Post(s)
Yea on the secondary fuel filter, I'm asking about(maybe wrong name) the fuel regulator that makes sure all injectors/cylinders get equal amount fuel. Am I saying that right?
Will it need to be re-adjusted if I do this blue spring kit upgrade?
twood71 is offline
post #4 of 15 Old 07-10-2019, 12:33 PM
Old School
Chris's Avatar
Quoted: 31 Post(s)
Garage
I believe he is referring to the adjustable blue spring kits out in the market. They pre-load the spring with an adjustable screw/nut which allows you to increase the pressure being applied to the spring. This is Sinister's version: https://sinisterdiesel.com/i-2408371...roke-6-0l.html
Before people start freaking out about it being a sinister product, it was just the first result when I searched.
2006 Ford F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, South Bend Dual Disc Clutch SFDD3250-6.0, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front and Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit, Morimoto LED Fog Lights, Bilstein 5100s
Fast, cheap, reliable...pick two.
Chris is offline
post #5 of 15 Old 07-10-2019, 12:33 PM
Quoted: 10 Post(s)
Garage
Unless you have an aftermarket regulator housing (I believe Sinister makes one) there is no adjustment. The spring itself is what allows the higher pressure - assuming your fuel pump (on the frame rail) is in good working order. If I remember correctly the blue spring is slightly longer than the stock spring.
Name:	blue spring.jpg
post #6 of 15 Old 07-10-2019, 12:39 PM
Quoted: 10 Post(s)
Garage
Yeah, that's what I was figuring. So I apparently attached a picture the same time you posted a link!
Chris likes this.
post #7 of 15 Old 07-10-2019, 02:47 PM
california deplorable
john galt's Avatar
Quoted: 3079 Post(s)
just going to add i would avoid sinister at all costs...
they are not what i would call a high quality or highly moral company.
the other thing is the blue spring is an actual ford fix to a known problem. there are a number of companies that ake a decent adjustable housing but all require the blue spring be included so...
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #8 of 15 Old 07-11-2019, 05:32 AM
SkullsMN's Avatar
Quoted: 2 Post(s)
Sad to hear Sinister isnít the quality they claim. I just purchased the adjustable blue spring housing kit. Havenít installed it yet.
Sent from my iPhone using Tapatalk
SkullsMN is offline
post #9 of 15 Old 07-11-2019, 06:14 AM
Sock Puppet's Avatar
Quoted: 550 Post(s)
Mine has been just fine.
SkullsMN likes this.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #10 of 15 Old 07-11-2019, 07:55 AM Thread Starter
twood71's Avatar
Quoted: 60 Post(s)
What is the name of this, I was told fuel regulator to control fuel delivery
ID:	720761   Click image for larger version
twood71 is offline
