Dash shuts off while driving - Ford Powerstroke Diesel Forum
LinkBack Thread Tools
Old 07-08-2019, 09:18 AM Thread Starter
Quoted: 2 Post(s)
Recently been having some weird issue. Truck will be running and driving fine but at certain points the dash shuts off( all needles down lights off) and the radio powers off completely but trucks still driving with that happening. After a few minutes it all turns back on but then does the same thing over and over again, any ideas?
6.0joe7 is offline
Old 07-08-2019, 09:43 AM
K9Gunner's Avatar
Quoted: 26 Post(s)
Check to wire on the gear shifter. Take plastic cover off ignition and see if this wire is rubbed and become bare. If so thatís your issue. Mine did same thing. It was bare and wrapped electrical tape around bare spot and never did it again
Sent from my iPhone using Tapatalk
2003 Ford F-350 6.0 Lariat. Edge Insight Pro CTS 2. Bone stock.
K9Gunner is offline
Old 07-08-2019, 01:11 PM
Quoted: 394 Post(s)
I already posted in your other thread (that you didn't respond to), when you posted about this issue.
This one is almost certainly Instrument Cluster issue (battery saver circuit).
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
