transfer case oil. xl-12??? - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 28 Old 06-24-2019, 09:55 PM Thread Starter
Quoted: 2 Post(s)
apparently there is new oil recommended for the transfer case of my 2006 f-250, and its called xL-12. anyone have any info? do I need to get motocraft XL-12, or is other XL-12 ok?
genezimmer is offline
post #2 of 28 Old 06-25-2019, 01:46 AM
Quoted: 23 Post(s)
It doesnt use auto trans fluid...?
Sent from my SM-G900V using Tapatalk
mohead1 is offline
post #3 of 28 Old 06-25-2019, 03:37 AM
00t444e's Avatar
Quoted: 540 Post(s)
Regular cheap Mercon rated atf works just fine.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #4 of 28 Old 06-25-2019, 04:00 AM
Quoted: 260 Post(s)
I have used Royal Purple's SynchroMax for 150k miles.
jokester00 likes this.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Bilsteinshocks; BPD EGR cooler;One-piece HPOP fitting;BPDWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #5 of 28 Old 06-25-2019, 04:44 AM
voodooridr's Avatar
Quoted: 869 Post(s)
XL12 has been replaced by Mercon LV
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
The Following 2 Users Say Thank You to voodooridr For This Useful Post:
jokester00 (06-25-2019)
post #6 of 28 Old 06-25-2019, 05:28 AM
Quoted: 260 Post(s)
I don't think you would want a low viscosity formula (like SP or LV) in the transfer case.
Mark
post #7 of 28 Old 06-25-2019, 06:30 AM
SparkyF250's Avatar
Quoted: 3069 Post(s)
Garage
Valvoline makes an XL-12 equivalent. Surprisingly called Valvoline Transfer Case Fluid
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
1991 F350 4x4, 7.3 IDI Flatbed, 5 speed...sold
2008 F250 SCLB 6.4...Sold
SparkyF250 is offline
post #8 of 28 Old 06-25-2019, 10:50 AM
Sock Puppet's Avatar
Quoted: 533 Post(s)
Those sneaky sonsabi....
SparkyF250 likes this.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #9 of 28 Old 06-25-2019, 11:04 AM
ZMANN's Avatar
Quoted: 3799 Post(s)
fords xl12 was the same viscosity and feel as Mercon LV IMO and VooDoo has provided us with the Ford sheet stating that xl12 is no longer the preferred fill (use Mercon LV )
6.0 flush pdf
ZMANN is offline
post #10 of 28 Old 06-25-2019, 01:41 PM
Quoted: 23 Post(s)
I have used tranny fluid in all xfer cases for the last 15 yrs or so....never an issue
mohead1 is offline
