transfer case oil. xl-12??? - Page 3 - Ford Powerstroke Diesel Forum
 8Likes
post #21 of 28 Old 07-01-2019, 09:24 AM
ZMANN's Avatar
Quoted: 3886 Post(s)
thanks !! ...
6.0 flush pdf
ZMANN is offline
post #22 of 28 Old 07-01-2019, 10:25 AM
Quoted: 9 Post(s)
Garage
I am not trying to argue with you.
I just pulled that from Identa-fix Specs chart. So my train of thought is anything DEXIII/MERCON or newer will be just fine.
Newer fluids usually have additional additives in them and are MOST of the time backwards compatible because they are replacing another fluid. Or they changed additives to, not sludge, stop shudder, be more electronics & wiring friendly and I am sure some other reasons I have no clue about.
But we are talking about a transfer case so the electronics and shudder shouldn't be an issue.
I use synthetic oils in everything on my vehicles but thats my personal preference.
I will shut up now.😊
Teazr is offline
post #23 of 28 Old 07-01-2019, 10:43 AM
voodooridr's Avatar
Quoted: 927 Post(s)
FWIW Mercon V says right on the bottle do not use in transfer cases so all ATFs are not created equal
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #24 of 28 Old 07-01-2019, 12:03 PM
ZMANN's Avatar
no one is arguing IMO just discussing
Mercon LV is not new so it did not supersede xl12
they must have determined a need to change the spec away from xl12
6.0 flush pdf
ZMANN is offline
post #25 of 28 Old 07-01-2019, 06:27 PM
SparkyF250's Avatar
Quoted: 3184 Post(s)
Garage
Not necessarily, it very well could have been a bean counter move. Less stock numbers.
Ford T-cases have been using Mercon, then XL12 for years without issue. The first time problems showed up was when they went from Mercon to Mercon V and started having T-case failures. Hence the note on the Mercon V bottle and the addition of XL-12. I'll bet they did some minimal testing and determined that LV didn't blow up T-cases so there it is, no more XL-12.
FWIW I have two bottles of XL-12 and two of the Valvoline equivalent on the shelf, guess what's going in my truck when I get around to changing the fluid?
It wouldn't be the first time the bean counters gave us crap so they'd have less stock numbers. Can you say Ford Gold?
I just read where they say do not use XL-12 in T-cases that call for Mercon LV, so there is a compatibility issue. So if you do plan on running LV in an 1980 - 2016 transfer case you may want to flush as much of the old Mercon/XL-12/DexMerc out before adding LV.
https://torqueking.com/product/737/1...er-case-fluid/
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #26 of 28 Old 07-01-2019, 06:47 PM
TRAXN's Avatar
Quoted: 5 Post(s)
More info or just confusion?
Motorcraft.com will say that LV is not for use in T case.
T case fluid just a modified bean to count?
FWIW, I used Full Synthetic Valvoline T case fluid in my recent change.
TRAXN is offline
post #27 of 28 Old 07-02-2019, 12:34 PM
The Evil Twin's Avatar
Quoted: 154 Post(s)
This says it is for T Cases. Lol.
https://www.fcsdchemicalsandlubrican...ission%20Fluid
The Evil Twin is offline
post #28 of 28 Old 07-02-2019, 12:48 PM
JustinOOO9's Avatar
Quoted: 1518 Post(s)
Garage
Feedback Score: 3 reviews
Well I mix a stout beer, honey and some used motor oil for my transfer case!
Sorry Just had to get my two cents in while I could.
Ford has been back and forward with transfer case fluid. Look at your owns manual (available free online) and find the closest fluid that's compatible. Ford will again in a few years say use X and not Y again anyways.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
