Already have a gremlin... - Page 2 - Ford Powerstroke Diesel Forum
 13Likes
post #11 of 20 Old 06-24-2019, 08:25 PM
SparkyF250's Avatar
Quoted: 3345 Post(s)
Garage
If you're only worried about losing the radio stations, I'm telling you they will still be there. My batts were out for about 3 days doing the oil cooler and the only thing I lost was the clock.
Red Ford likes this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #12 of 20 Old 06-26-2019, 03:59 PM
The Donkey Hammer's Avatar
I had a the jolting problem on my 05, chased it for a long time. It was intermittent, some days constant followed by weeks of normal operation.
I replaced the IPR and IPC sensor, fuel filters ect...
It ended up being the IPC harness, I split the harness loom for troubleshooting and found 1 of the 3 IPC wires was being pinched against the hoist bracket.
The wire strand had broken inside the insulation so at a quick glance it appeared ok.
Solution : spliced in a new section of gxl wire with a new pigtail and rerouted wires exiting the loom at a better position.
Haven't had the jolting problem since, your solution may be different.
SparkyF250, djmaguire and Red Ford like this.
The Donkey Hammer is offline
The Following 2 Users Say Thank You to The Donkey Hammer For This Useful Post:
Red Ford (06-27-2019)
post #13 of 20 Old 06-27-2019, 02:06 PM Thread Starter
Red Ford's Avatar
Quoted: 1008 Post(s)
Garage
Thank you, I'll check into that. I got the new batteries but I'm having the same kind of problem where it's intermittent so I don't know if it fixed it or not. I have no hopes of the batteries fixing it, I just got tired of having to jump the truck if I let it sit for a day lol.
2005 F-350 Lariat, studded, Sinister diesel EGR delete, Sinister diesel coolant filter, MBRP 4" straight pipe, Banks ram air intake, SCT X4 tuner, blue spring, EGT sensor, fuel pressure sensor, 4" lift, 08 style mirrors, 35x12.5R20 Toyo RT
SOLD:
2006 Ford F-250 King Ranch FX4 crew cab short bed
4" flood lights for back up lights, High idle switch, 2008-16 tail lights, 2011-16 style 6.0 Powerstroke badging, Edge Insight CTS2, Blue spring mod, Viofo A119 dash cam, 275/70R18 BFG KO2, 2017 style mirrors, 2.5" lift coils, F-350 blocks in the rear, Riffraff CAC boots, Backup camera with spot lights in the rear, SCT X4 tuner, Fab Fours black steel series bumper with pre-runner guard, Mishimoto coolant filter, 4" Diamond eye turbo back straight pipe exhaust, 18x8.5 American Eagle Alloy Hardrock series 0168, 7.3L Fan clutch (Hayden 2835), Spyder LED tube projector headlights
2011 F-350 King Ranch FX4 crew cab long bed 325/65R18 BFG KO2, 18x8.5 American Eagle Alloy Hardrock series 0168, Steelcraft Elevation Bullnose Front Bumper, 20" front light bar, MBRP 4" DPF delete competition pipe, SCT GTX tuner with Tyrant tunes, Rough Country 1.5" leveling kit, Auxbeam LED headlights and fog lights, platinum style grill, black mirror lights
Red Ford is offline
post #14 of 20 Old 06-27-2019, 11:02 PM
So far you have done everything I did and we have the same year 2005 truck. When I looked at the harness. I found the damaged portion near the IPC sensor at the location of the harness Y split that was smashing one of the 3 wires of the sensor connector.
Good luck and happy hunting.
post #15 of 20 Old 06-29-2019, 06:20 PM Thread Starter
Red Ford's Avatar
Garage
Right where it splits off like a couple inces away from the ICP its self? I haven't got time to look into it thoroughly yet, hopefully I will tomorrow lol.
SOLD:
Red Ford is offline
post #16 of 20 Old 07-05-2019, 09:47 AM
Yes that's the location
post #17 of 20 Old 07-09-2019, 03:29 AM
So did you find anything?
post #18 of 20 Old 07-12-2019, 02:12 PM Thread Starter
Red Ford's Avatar
Garage
Unfortunately I haven't had time. Between working dumb long hours, making my girlfriends parents house handicap accessible (her mom broke her leg), and trying to figure out how I can get a mortgage I'm lucky to have time to shower haha.
SOLD:
Red Ford is offline
post #19 of 20 Old 07-14-2019, 04:20 PM Thread Starter
Red Ford's Avatar
Garage
Well I had some time today to look at the wires. I cut open the shielding and right by the ICP looks good and everywhere that I was able to see appeared good. I pressed down on the connection and felt a little snap like it was half way plugged in but not fully. I'm still trying to maneuver my fat butt around to follow the rest of the wires today while I have time off but I'm hopeful that that snap was plugging it in fully. I doubt it but it's always nice to hope lol.
SOLD:
Red Ford is offline
post #20 of 20 Old 07-14-2019, 06:25 PM
If the connector went snap i would see how it goes eg run it
