Air Bags for rear suspension. - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 13 Old 06-21-2019, 12:24 PM
Quoted: 17 Post(s)
I'm buying these when the time comes. Life priorities changed, so won't "need" them for a bit longer.
https://www.amazon.com/Air-Lift-8839.../dp/B00B32DFEC
2006 F-250 KR CCSB
ARP'd, Deleted, L-N Alt+1/0, Blue Spring,
ScanguageII, Sinister Coolant Filter,
FICM Economy Tune, 4" MBRP, aFe Intake,
Riff Raff Boots, Metal Cold-side CAC Pipe, Ravelco,
Amsoil DIY Bypass, Dieselsite Waterpump,
133k+, Auber EGT/Fuel/Coolant/LPO Gauges, 6.4 Pan
rtr688 is offline
post #12 of 13 Old 06-21-2019, 12:37 PM
ZMANN's Avatar
Quoted: 3949 Post(s)
i am not a fan of over the axle vs over the spring bags
some applications you have to use them but i built my own mounts for the 7500 bags since nothing was available at the time
6.0 flush pdf
ZMANN is offline
post #13 of 13 Old 06-21-2019, 01:01 PM
Sock Puppet's Avatar
Quoted: 570 Post(s)
Something else to consider that I remember when shopping, is that some gooseneck hitches will interfere with the air bag brackets. Be sure to check that out if you have anything else mounted to the frame in that general area.
ZMANN likes this.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
