Towing with a tuner - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By G8orFord
post #1 of 9 Old 06-18-2019, 10:36 PM Thread Starter
Lostownloser's Avatar
Quoted: 2 Post(s)
Towing with a tuner
Ok so don’t jump down my throat with this. But I’m running a sct tuner about to pull a trailer on a pretty reasonably big camping trailer and I’m going to use the towing tune. But do I still use the towing button on my shifter while running the towing tune? I already realize I’m not the sharpest tool in the shed just not sure what to do. All feed back welcome.
Lostownloser is offline
post #2 of 9 Old 06-19-2019, 05:00 AM
jman37's Avatar
Quoted: 400 Post(s)
Garage
Is it a generic SCT tow tune? Or is it from a reputable tuner? I would just monitor your temps to make sure everything is good and take it easy. You can still use the tow-haul button while using a tow tune.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #3 of 9 Old 06-19-2019, 05:32 AM
R&Rpowerstroke's Avatar
Quoted: 108 Post(s)
Garage
All tuners I have spoke with recommended to always use tow haul when pulling the camper. I am guessing you used the tow tune that came with the SCT but did you also choose the Tow tuning for the transmission? Also make sure you have a couple hundred miles on your time before you hook up to your trailer since these trucks need to relearn parameters in the transmission. Good luck on your outing and enjoy camping 😉.
03 250 ccsb blue spring, UCF ported and polished heads, Odawg SR3, ficm tuner, SCT x4 with custom tunes, 4" turbo back to 6" tip, Magtec diff covers, Amsoil fluids, ARP 625's, Airlift bags, Kc stage 1, Dieselsite hpop, Vision Hauler 19.5's, No Limit intake, full on board air with 8.5 gallon tank, train horns, Sinister degas, DieselSite water pump, Big Wig rear sway bar, 7.3 clutch fan, BPD adapter
Wife's new ride 2019 F450 Lariet Ultimate CCLB 4x4
R&Rpowerstroke is offline
post #4 of 9 Old 06-19-2019, 07:00 AM
G8orFord's Avatar
Quoted: 2607 Post(s)
Garage
Use it if you need it. Not sure about the generic SCT tow tune, but many custom tow tunes add a little exhaust brake when the T/H is activated. This can be handy on hills. Depending on the weight and overall health of the truck, you may not really need T/H for flat ground towing. Other than the exhaust brake, all T/H really does is delay upshifts to allow the RPM to stay up. Once you're cruising in O/D it makes no difference.
R&Rpowerstroke likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #5 of 9 Old 06-19-2019, 08:57 AM
Calkidd's Avatar
Quoted: 4 Post(s)
What tow tune are you using? And yes you still want to activate the tow/haul button. I have Eric's tow tune and haul a 38' toyhauler.
Calkidd is offline
post #6 of 9 Old 06-19-2019, 02:32 PM
I have a 2006 F-250 and I have been using the SCT stock 50HP tow tune with the tow transmission setting on. I do like the 50HP tune over the 85HP (I think) tune that comes with the SCT tuner. I want to do a DYNO tune on the truck but I can't seam to find a place near Denver that will do a DYNO tune for our trucks. If you know one let me know I would love to get mine done.
SILVER6.0FREEDOM is offline
post #7 of 9 Old 06-19-2019, 03:52 PM
Quoted: 22 Post(s)
First off. Monitor EGT’s
Play with the tow haul button and see what you prefer. Like @G8orFord said there are things the button does. I prefer to engage it ONLY when ascending or descending otherwise I leave it off. I like that it keeps the rpm up when ascending and I like the downshifting it does when descending. I towed with it on during my entire trip last month. I will most likely revert back to only using it to descend/ascend. For me my MPG suffers if towing with it on the entire trip.
Larry Grogan is offline
post #8 of 9 Old 07-14-2019, 03:30 PM
Smitty02's Avatar
Quoted: 22 Post(s)
So you like Eric's tow tune? I have a F550 and am looking for a good tow tune to use when towing my 42' toy hauler. The truck has 4.88 gears.The trailer is close to 20K when loaded down with all the toys and gear.
2006 F550 Lariat Superduty
Link UltraRide System
4.88 Rear Gear
Banks Big Hoss Bundle
Banks intake
Banks Intercooler
Diesel tech "Bullet Proof" kit
Bullet proof EGR cooler
BPD External Oil Cooler system
Coolant filter bybass system
ARP head studs
40gal aft axle fuel tank
50gal TransFlow/Took box
Rhino lined bed
24K Air Safe 5th Wheel hitch
19.5 Alcoas with 225/70/19.5s
SCT SF3 3015 Tuner
Edge Evolution CTS w/EGT
4" Turbo Back Silverline Exhaust, 5"tip
Smitty02 is offline
post #9 of 9 Old 07-14-2019, 08:56 PM
Calkidd's Avatar
Quoted: 4 Post(s)
I like his tow map the best. I get lower EGT's and it gives just a touch of extra HP over stock.
Calkidd is offline
