Crank, no start. Pic of Torque Pro #s. HPOP? - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 12 Old 06-18-2019, 06:19 PM Thread Starter
2004.5 with round style hpop. It tries to start but just unable too... long cranking and these are the numbers that come up on torque pro. Any ideas? I have sinister regulated return fuel system, never had issues with injectors. Oil cooler replaced about 30k miles ago. Truck just stalled driving on the highway. Any ideas?
Name:	Screenshot_20190618-221143_Samsung Internet_1560910670873.jpg
Powerstroke2004.5 is offline
post #2 of 12 Old 06-19-2019, 03:06 AM
Thesoulless's Avatar
Quoted: 10 Post(s)
Garage
At a quick glance your IPR looks high (85% is full open) so it may be a HPO leak. Any codes? What are the numbers KOEO? Do you have Torque setup to log PIDs, if so do you have the logs? Was it a long crank problem when hot? When cold? Always?
2003 Excursion 6.0, 2004 front cover, Stock head bolts, unknown EGR delete, 4" Diamond Eye turbo back exhaust, Magnaflow 60110 catalytic converter (makes the '03 whistle livable), Hellwig Sway bar, Roadmaster Active Suspension, Gearhead tunes - 8k tow or SRL depending on my level of 6.0 paranoia, unknown work by previous owners...
Thesoulless is offline
post #3 of 12 Old 06-19-2019, 05:03 AM Thread Starter
No codes. It just doesn't start... HPOP gets to the 600s.... as if it almost wants to start but doesn't. Just stalled on highway cruising at 60 mph... what are KOEO? FICM rebuilt..... Diesel tech Ron has it as HPOP.... because it's an 04 style HPOP... I hope it is. But the injectors look easier to replace then an HPOP.
post #4 of 12 Old 06-19-2019, 06:03 AM
G8orFord's Avatar
Quoted: 2465 Post(s)
Garage
Technically, it should start at 600 psi. How much fuel is in it? 1/4 tank or below? Does the RR have a gauge on it?
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #5 of 12 Old 06-19-2019, 11:49 AM Thread Starter
Over 3/4 tank full... with some AMSOIL fuel injector cleaner
post #6 of 12 Old 06-19-2019, 05:18 PM
G8orFord's Avatar
Garage
Fuel pressure gauge?
Hydro likes this.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #7 of 12 Old 06-19-2019, 05:33 PM
Quoted: 10 Post(s)
Garage
Key On Engine Off, it's a check to see if your sensors are reading as they should (IPC voltage, Fuel pressure, IPR, etc). Did you go through the no start checks? Or are you saying HPOP because it's the early style? There's a lot of o rings and potential leak points in the HPO system. Like g8or said, have you checked the regulated return system as well?
post #8 of 12 Old 06-19-2019, 05:57 PM Thread Starter
Found a video from dieseltech Ron that shows exactly what is going on with my truck... I have the 586 ICP pressure to start... in theory... but does not start.. *Ron had a truck with the exact issue with ICP at 600 psi and still no start.. .. states most likely it's the pump since it's an 04... * go to minute 6:20 and this is EXACTLY how my truck sounds... exactly. *
Watch "2003 early 04 Ford 6.0 Powerstroke diesel no start" on YouTube
https://youtu.be/T09gCEDxhz4
post #9 of 12 Old 06-19-2019, 06:14 PM
Quoted: 10 Post(s)
Garage
Understood, and I'm not saying it isn't the pump, just pointing out - as Ron does - that checking the IPR and oil system for leaks should be done prior to throwing a pump at it (6:32 in the video), especially since the 2004.5 has the updated oil rails with the stand pipe/dummy plug setup. If you replace the pump and have a chewed up o-ring you'll still be chasing a long crank or no-start condition. But, whatever you find the fix to be, please post that.
Hydro likes this.
post #10 of 12 Old 06-19-2019, 06:42 PM
Quoted: 284 Post(s)
Garage
Just FYI:
the 85% reading is the PCM commanding the IPR "closed" -- the valve(IPR) is used as a dump for the HPOP -- the HPOP has full access to the oil rails and the valve dumps off any oil that is not needed
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
