2006 FICM voltage - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By djmaguire
post #1 of 6 Old 06-16-2019, 10:00 AM Thread Starter
gbb
2006 FICM voltage
Good old intermittent start whether hot or cold. When normal key turned on 48V. When no start condition notice voltage delays. in high 20's before achieving the full 48V. Ficm or external?
gbb is offline
post #2 of 6 Old 06-19-2019, 09:02 AM
Calkidd's Avatar
Quoted: 4 Post(s)
This post is a little confusing. "No start condition" what do you mean? Have you tested the voltage while your cranking the motor? When you say high 20's is this while it's cranking or after the engine has started?
Calkidd is offline
post #3 of 6 Old 06-20-2019, 06:16 AM Thread Starter
gbb
Voltage when cranking.. Once started will achieve normal voltage. Drove 40 miles last nite and started normal.
gbb is offline
post #4 of 6 Old 06-20-2019, 07:31 AM
djmaguire's Avatar
Quoted: 1587 Post(s)
Garage
Change the FICM power board or the FICM itself. Low FICM voltage kills injectors. I wouldn't wait very much longer.
partyman97_3 likes this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
The Following 2 Users Say Thank You to djmaguire For This Useful Post:
gbb (06-21-2019)
post #5 of 6 Old 06-20-2019, 09:47 AM
Sock Puppet's Avatar
Quoted: 573 Post(s)
Yep, and it's pretty easy to do. I chose the TechSmart board and I haven't seen below 48.5 since installation.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #6 of 6 Old 06-21-2019, 04:53 PM Thread Starter
gbb
Have 3 Ficm boards from previous issues. Going to sweat solder joints on all my boards. Not an issue as been electronic tech for 40 some years. Have a 2003 and 04 f350 . Between the two have 1.1km on them. 700k miles. 04/06 motor I did hpop and plugs and pipes. It is running with original EGR oil cooler etc.. All original. Was wondering if my standpipe orings were giving out. Used to snap when started. Now bit sluggish. Don't have scanner so if hpo issue may just plumb pressure gauge on IPR port.
gbb is offline
