CCV Filter - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 31 Old 06-14-2019, 07:59 AM Thread Starter
Quoted: 25 Post(s)
CCV Filter
Anyone using or tried a Parker CCV Filter.....want to use one on my F350
https://www.rg-group.com/products?fi...se-filtration/
Sent from my SM-G900V using Tapatalk
mohead1 is offline
post #2 of 31 Old 06-14-2019, 08:19 AM
Quoted: 335 Post(s)
I use that exact one. Some people went w/ the size smaller, but I think the 6000 is the best choice.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 31 Old 06-14-2019, 08:43 AM Thread Starter
Quoted: 25 Post(s)
Cool, does it work well keeping oil separated...how long does a filter last? And i want to mount on the frame, is that gonna be doable
mohead1 is offline
post #4 of 31 Old 06-14-2019, 09:28 AM
Quoted: 335 Post(s)
Mine is mounted on the frame (drivers obviously). How often you change it depends on the amount of blow-by on your engine. I go a year on the filter element. Probably could go longer. Just drain it often at first so that you can get an idea of how fast an oil level accumulates. I put a drain valve (ball valve) on it (one I got from Home Depot or Lowes) for air compressors.
Use 1 inch hose. Try not to leave dips in the hose that collect oil. Constant down-slope to the filter. Constant up-slope from the filter.
mohead1 likes this.
Mark
No-start thread:
bismic is offline
The Following User Says Thank You to bismic For This Useful Post:
mohead1 (06-14-2019)
post #5 of 31 Old 06-14-2019, 11:06 AM
ZMANN's Avatar
Quoted: 3913 Post(s)
I run the same and it is sized right for the 6.0
also mounted on the drivers frame
I used this hose https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
as for the connections to the valve cover i used the elbow swap you can google about
6.0 flush pdf
ZMANN is offline
post #6 of 31 Old 06-14-2019, 01:00 PM
joe blow's Avatar
Quoted: 127 Post(s)
Yep,
It works well for me. I still get a mist of oil in the tubes somehow, but it is very light.
Nothing like it was when stock
joe blow is offline
post #7 of 31 Old 06-14-2019, 01:30 PM
ZMANN's Avatar
i get a decent amount of oil out of the separator when i drain it every 3-4 months
i have not opened my CAC up since I have had the 6000 on ( 3 years) i am curious to take a peek
6.0 flush pdf
ZMANN is offline
post #8 of 31 Old 06-14-2019, 01:40 PM Thread Starter
Quoted: 25 Post(s)
Im sorta disappointed....i thought this thing was one of the top of the line separators, but you are still getting oil by?? Im trying to eliminate oil back to the turbo and into the intercooler.
mohead1 is offline
post #9 of 31 Old 06-14-2019, 02:01 PM
JustinOOO9's Avatar
Quoted: 1575 Post(s)
Garage
Feedback Score: 3 reviews
You will never fully eliminate the oil residue in the system unless you route to atmosphere. You hear a few who claim zero in the intake after just adding a catch can but never seen one my self.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is online now
post #10 of 31 Old 06-14-2019, 02:28 PM
Quoted: 335 Post(s)
WHS ^.
The amount I see is barely enough residue to coat the surface of the intake tube. Definitely nothing pooling.
The better way to look at it is to see how much drains out - all that would have gone through the system.
As Zmann stated - I too get a decent amount out of the separator (ie out of the ccv filter canister).
IMO they work VERY well. If you want perfect though ............
Mark
No-start thread:
bismic is offline
