Lowest A/C vent temps in 90 degree Florida weather? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-13-2019, 05:19 PM Thread Starter
Quoted: 18 Post(s)
My a/c system was low on freon so I have filled it to pressures 32/175 at about 80 degrees out. It was almost 90 degrees out today and I am able to get the a/c vent to the right of the steering wheel at 45 degrees on recirculate on the second lowest setting. Should the I be able to get the temp in the 30's or should I not mess with anything?
Invasivore is offline
post #2 of 4 Old 06-13-2019, 07:00 PM
Quoted: 318 Post(s)
Garage
Yeah, that temp and pressures are about right -- an orifice tube system is never gonna be as cold an expansion valve system
Another thing to consider with a 'leaky' system that you need to add gas to very many times is the makeup of the refrigerant(134) -- you will usually see the low pressure reading be higher than it should and not get the cooling
134 is a mixture of gasses and the part with the smaller molecules will leak out leaving the larger molecule gas as the only one in the system -- without the proper ratio, the system will not cool as well and have higher low pressure readings
Evacuating the system and starting out with a fresh 134 gas will fix the problem -- fix the leak first
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 4 Old 06-14-2019, 03:59 AM
The Evil Twin's Avatar
Quoted: 153 Post(s)
Any lower than 40° supply air and you may get evaporator frosting at lower ambient temps. The coil surface is several degrees lower than your supply air.
134a is a zeotropic refrigerant. You can charge it as a gas or liquid because it is not subject to fractionation. You might be thinking of 410a which you do have to evac + charge if it leaks because the blend ratio will change o
Last edited by The Evil Twin; 06-14-2019 at 04:00 AM. Reason: forgot quote response
The Evil Twin is offline
post #4 of 4 Old 06-18-2019, 06:11 AM Thread Starter
Quoted: 18 Post(s)
Should I bump it up to 40 psi on the low end?
