Head studs or not? - Ford Powerstroke Diesel Forum
 75Likes
post #1 of 112 Old 06-12-2019, 04:57 PM Thread Starter
Quoted: 19 Post(s)
Head studs or not?
I picked up a 05 F350 4x4 with crew cab the whole nine yards. It has singles it's lifted and is a decent looking truck for the most part. I bought it cheap because it has blown head gasket. I'm tearing it down in cab, I should be pulling the heads tomorrow as everything is done up to that point..
(fyi I watched a lot of youtube vids on doing this in cab and I never saw anyone say to pull the inner fenders. I pulled mine and it makes this job a lot easier)
Anyway the truck has about 230k. The motor ran and sounded great before I took it apart, the heads are very clean inside so far so they obviously changed the oil routinely.
I'm curious what the opinion is on if I should bother spending the $400+ on head studs for a 200k+ motor or should I just put bolts back in? I do not intend to replace the heads assuming they aren't severely cracked.
I don't really want to spend $3-4k on a 200k+ motor. If I was going to spend that much I'd probably do a cummins swap to be honest. I'm not trying to cheap out and I'm not on a strict budget but I'm also not going to sink needless money into it because someone said oh you have to replace XYZ on everything always...
My intended use of the truck is for right now to be my daily driver, but there is a possibility I may use the truck later on to do some hotshot work. I used to drive semis and I'm planning to set up my own authority and run a hot shot truck. More than likely I would upgrade to a duelly once I did that so I'm not really building this truck with the intention of using it full time towing but it does have the potential to be used for that at some point.
edit.. for the record it's been deleted already and has 4" straight pipe. Possibly has had the turbo upgraded as well. I also have a 06 6.0 in a van and this truck even with the blown head gasket has a lot more power than the van.
Should I head stud it or not?
edit... one other question.. My starter needs replaced. I've seen people say they have 6.4 starters on their 6.0's. Is there a good reason for upgrading to that?
DAV!D is offline
post #2 of 112 Old 06-12-2019, 05:40 PM
Quoted: 21 Post(s)
I would stud it. How much is your time worth ? I would rather do the job once and be done. If you run it bone stock it may be fine on the POS TTY bolts if you run a programmer or flog on it, best of luck. To me a few hundred dollars to not have to dig in to the damn thing again is money well spent, that being said studs do not fix all the shortcomings.
If it were me on the starter I would get the 6.4 it spins faster. If you buy a reman unit it may be a 6.0 core that someone turned in when they bought a 6.4 starter so you may be getting a rebuilt 6.0 unit thinking it is a 6.4 unit. Due to this I would buy new.
Larry Grogan is offline
The Following User Says Thank You to Larry Grogan For This Useful Post:
DAV!D (06-12-2019)
post #3 of 112 Old 06-12-2019, 05:46 PM
G8orFord's Avatar
Quoted: 2465 Post(s)
Garage
You likely would not do a Cummins swap for anywhere near $3-4k, unless already a a donor, so that comparison doesn't really fly. IMO, since you aren't on a tight budget, I'd definitely do the studs. 230k isn't that much on a well maintained 6.0. The bottom end is pretty stout. You'll likely still see crosshatching in the cylinders when you get the heads off. Your call though.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
The Following 2 Users Say Thank You to G8orFord For This Useful Post:
DAV!D (06-12-2019)
post #4 of 112 Old 06-12-2019, 06:24 PM Thread Starter
Quoted: 19 Post(s)
I wasn't saying I would do a cummins swap for $3-4k but if I was spending that much on a 200k+ motor I'd do a swap instead. I have however swapped other motors that people say you can't do it for less than blahh..blahh blahhh and I've always done it very cheap..
There is no real reason you can't swap a Cummins for $4k btw.. The reason people spend $5k+ is because they buy all the aftermarket make everything easy kits. You build your own ****, keep it stock and costs are dramatically reduced.
DAV!D is offline
post #5 of 112 Old 06-13-2019, 05:21 AM
Heavy_GD's Avatar
Quoted: 3091 Post(s)
Garage
Feedback Score: 3 reviews
Im not sure if you are here for companionship or just to tell us how good you are at building cheap stuff.
joe blow and jman37 like this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
The Following 2 Users Say Thank You to Heavy_GD For This Useful Post:
joe blow (06-13-2019)
post #6 of 112 Old 06-13-2019, 05:46 AM
jman37's Avatar
Quoted: 294 Post(s)
Garage
I want to know where he's finding a Cummins for 4k since that's what he said it would take. Most clowns charge that for a 300k beat 12v.
Heavy_GD likes this.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's
'88 Mustang LX - Built 306ci, built AOD, 4.10's
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #7 of 112 Old 06-13-2019, 07:04 AM
joe blow's Avatar
Quoted: 126 Post(s)
SMH.....I thought the same thing
2004/Kill Devil O-ringed heads/Studs(finally)/Warren 175-30's/ADII/KC StageII/BPD everything/ODAWG S2R Ported Intake/CX racing IC/Gearhead Tunes/WPE RR...........FINALLY DONE and (still) NO LEAKS!
Joe
joe blow is offline
post #8 of 112 Old 06-13-2019, 07:23 AM
jman37's Avatar
Quoted: 294 Post(s)
Garage
I mean, built cheaply and diesel don't go good together. Ford learned that when they put in bolts and not studs, and here you are asking if you should put bolts back in?
Heavy_GD and Jjorgis5569 like this.
jman37 is offline
post #9 of 112 Old 06-13-2019, 07:40 AM
Heavy_GD's Avatar
Garage
We've also learned that when that cheap chit breaks, they come back here.
GD
Heavy_GD is offline
post #10 of 112 Old 06-13-2019, 09:42 AM
joe blow's Avatar
Quoted: 126 Post(s)
OP....stud it unless you love tearing into this truck repeatedly or you like taking stupid chances and love rework.
The 6.4 starter is a good option and spins the engine much faster, I did a reman from O'reillys and it has been flawless for a while now.
Going cheap will eventually bite you....I have found out the hard way with past projects.
If I had to do it all over again, the only thing I would change on mine is I would have replaced the HPOP with a dieselsite model when I had the engine on a stand.
The only saving grace is mine only had 100k on it and the advice given to me here was enough to let it ride for another 100k.
Joe
joe blow is offline
The Following User Says Thank You to joe blow For This Useful Post:
DAV!D (06-13-2019)
