04 f350 6.0 how do I do a coolant flush? - Page 2 - Ford Powerstroke Diesel Forum
 5Likes
post #11 of 31 Old 06-02-2019, 03:19 AM
Quoted: 451 Post(s)
That is what I did also, except I used 3.5 gallons of concentrate. The total system is 28 quarts (7 gallons).
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #12 of 31 Old 06-02-2019, 10:46 AM Thread Starter
billharrisjr's Avatar
Quoted: 4 Post(s)
Originally Posted by PowerSmoke07 View Post
Me personally, I love making a huge mess once so that I don't have to make a mess again in the future. So I pulled my starter (after disconnecting the batteries), pulled both block plugs and opened the radiator pet****, once drained I installed valves, reinstalled the starter, pulled out the thermostat, reinstalled the empty housing. Then proceeded to flush the crap out of it. Filled it with distilled water, ran it for 15 minutes on high idle with the heater on, drained it, filled it and put in Restore, ran it, drained it, filled it, ran it, drained it, filled it and put in Restore+, ran it, drained it. Then fill, run, drain until it's clean on a pH test strip. All in all it took me about 40 gallons of distilled water. When you're done and refilling the cooling system for good, put 3 gallons of CONCENTRATED coolant in FIRST since there will still be a little bit of water left in the system, then top off with distilled water to get damn close to a 50/50 mix, drive it around to burp out any air bubbles, top off with distilled to the line and you're done
Awesome! Thank you! So disconnect batteries, unbolt starter to get to other plug, pull other plugs, drain, run water through the system until it’s clear, bolt starter back on, connect batteries, start truck, continue to flush, do that a few times, then plug everything and fill with coolant?
I just need to figure out how to pull the starter now.
billharrisjr is offline
post #13 of 31 Old 06-02-2019, 10:52 AM
voodooridr's Avatar
Quoted: 1055 Post(s)
I would install a Fumoto valve when you pull the starter, then you only need to pull the starter once
bismic likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #14 of 31 Old 06-02-2019, 04:10 PM Thread Starter
Quoted: 4 Post(s)
Isn’t that an oil valve?
post #15 of 31 Old 06-02-2019, 04:15 PM
ChrisSki's Avatar
Quoted: 587 Post(s)
Try the F108n Fumoto valve and attach some 3/8" tubing to the valve on the first flush to make the rest quicker and less messy.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #16 of 31 Old 06-02-2019, 04:40 PM
voodooridr's Avatar
Originally Posted by billharrisjr View Post
Isnít that an oil valve?
It's a fluid valve, i don't think it cares what fluid it's controlling
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #17 of 31 Old 06-02-2019, 05:07 PM Thread Starter
Quoted: 4 Post(s)
If I do that I should have to unbolt the starter?
post #18 of 31 Old 06-02-2019, 05:15 PM
voodooridr's Avatar
Just once, install the valve then slip a piece of tubing on the valve and loop it past the starter
SparkyF250 likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #19 of 31 Old 06-03-2019, 04:02 PM Thread Starter
Quoted: 4 Post(s)
So there’s a twist now. The starter is has putty holding one of the bolts secure so the started doesn’t fall out. The hole that connects the starter to the tranny is broke so hence the putty or else the starter wouldn’t stay in place. There’s no way to get my starter off. Could I just take the the driver side plug out or should I just take it in and have them tap into the hoses and flush it that way?
post #20 of 31 Old 06-03-2019, 04:08 PM
ZMANN's Avatar
Quoted: 4004 Post(s)
two bolts will hold that starter on ok
i have read about the starters working right up till they fell off the truck ( last bolt worked out )
if you don't pull the starter to get the drain plug you will be doing a poor job on the flush
6.0 flush pdf
ZMANN is offline
