Intermittent hot start issue question - Page 2 - Ford Powerstroke Diesel Forum
 9Likes
post #11 of 15 Old 06-06-2019, 07:22 AM
Quoted: 300 Post(s)
IPR:
IPR should be around 14% (10% - 15% is ok) DC @ key-on-engine-off
IPR should be around 40-60% (80 is possible) DC when cranking.
IPR should be 22-24% at hot idle (MAYBE as high as 29%)
IPR should be 26 - 27% at cold idle
ICPv:
0.15v - 0.35v (typical is 0.19-.24v) KOEO, no pressure registering on my HPO gauge
0.8v to 0.9v cranking typically - could be higher though, around 520 to 650 psig
0.82v - 0.85v at hot idle - around 520 - 600 psig
1.25v - 1.35v at cold idle - around 860 - 960 psig
bismic is online now
The Following 2 Users Say Thank You to bismic For This Useful Post:
joe blow (06-06-2019)
post #12 of 15 Old 06-06-2019, 07:56 AM Thread Starter
joe blow's Avatar
Quoted: 127 Post(s)
Awesome!
Thank you very much
joe blow is offline
post #13 of 15 Old 06-06-2019, 09:54 AM
G8orFord's Avatar
Quoted: 2518 Post(s)
Garage
Originally Posted by bismic View Post
IPR:
IPR should be around 14% (10% - 15% is ok) DC @koe O
ICPv:
We have a member named @koe ? I wonder if he meant to make KOEO? That would be semi-hysterical.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #14 of 15 Old 06-06-2019, 11:09 AM
Quoted: 300 Post(s)
lol .
post #15 of 15 Old 06-07-2019, 08:06 AM Thread Starter
joe blow's Avatar
Quoted: 127 Post(s)
After receiving my new relay I disassembled the relay that gave me the no start issue. The contact points were pitted but not burnt like some bad ones I have seen in the past. 100k is a good benchmark for this working relay's life I guess.
joe blow is offline
