Coil Spring Axle Swap - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 33 Old 05-25-2019, 02:51 PM Thread Starter
Weberman3's Avatar
Quoted: 634 Post(s)
Send a message via MSN to Weberman3
I decided to start a thread to show the swap eventually but mainly for now show the progress being done to it.
Here is the axle when first being brought home
Plans are probably go through everything and see what needs to be replaced since it will be a lot easier out of the truck. I'll probably replace everything that has boot that is pretty cracked or torn. Paint everything before it goes under. Open to suggestions on what to do now and while I'm moving through the project.
2004 F350 XLT 6.0L ZF6 CCSB
ARP Head Studs, EGR Delete, 4" Turboback, Fuel Sump, Coolant Filter, NUC Oil Bypass Filter
Kenwood DDX372BT with Rear View Camera, Rockford Fosgate P1683 speakers, Infinity REF1200 subwoofers
Weberman3 is offline
post #2 of 33 Old 05-25-2019, 04:15 PM
partyman97_3's Avatar
Quoted: 880 Post(s)
Garage
Subbed in for the progress. What year was your donor truck.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #3 of 33 Old 05-25-2019, 05:42 PM Thread Starter
Weberman3's Avatar
Quoted: 634 Post(s)
Donor truck is from a 2009, I'll hopefully be getting the rear axle from it too. I just got the front because the rears are much cheaper and I know for sure it will work..I've seen some people say that the rear changed in 2008 to require a different length driveshaft, but these were Excursion threads and the one Superduty thread that mentioned a 2008-2010 said that it is okay. It will be a bigger pain for me if it is different because of the ZF6, let alone in 6.4s. It will probably have to be a custom driveshaft if so.
partyman97_3 likes this.
post #4 of 33 Old 05-25-2019, 06:01 PM
Quoted: 25 Post(s)
I want to do this on my 97 OBS F250 w the 7.3 Powerstroke. Will be watching closely. I want to see how and where the spring mounts get put in for the front. The rear shud be no big deal. Need to know how much fabrication is required, whether kits are avail, and getting the axle aligned to the truck as square as possible
Sent from my SM-G900V using Tapatalk
mohead1 is offline
post #5 of 33 Old 05-25-2019, 06:19 PM Thread Starter
Weberman3's Avatar
Quoted: 634 Post(s)
A lot of the holes exist already. You can put the radius arm brackets on before so you fan get all that ready. The shock towers unbolt and those holes line up with the coil bucket and you can drill holes from there. I think the only major holes are the track bar bracket, only one is there so you can line it up, but the rest of the holes are missing.
post #6 of 33 Old 05-25-2019, 06:41 PM Thread Starter
Weberman3's Avatar
Quoted: 634 Post(s)
Shoot just saw that it was a 97. I imagine it can be done still with no kit but it may make it easier for you due to placement but it could still be done I bet.
The wheel bearings already feel good but I went ahead and greased them more through the ABS hole. I greased the U joints too while I was near. Does anyone know if 05-10 axles came factory with greaseable ones? I don't think they would as mine don't, but maybe that was part of the change. I know that both sides are greaseable and only one ball joint is greaseable so I assume that whoever had it just did bare minimum if it need to be replaced, but maybe both U joints needed to be replaced.
post #7 of 33 Old 05-26-2019, 06:24 AM
backhoebill's Avatar
Quoted: 1245 Post(s)
Send a message via Yahoo to backhoebill
My 06 and my 2011 are not greasable
Sent from my iPhone using Tapatalk
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #8 of 33 Old 05-26-2019, 09:30 AM Thread Starter
Weberman3's Avatar
Quoted: 634 Post(s)
Is the Track bar a 30mm or around there? Was wanting to get it off to paint the bracket but I don't have a metric that will go over it and my standards are sloppy
post #9 of 33 Old 05-26-2019, 10:05 AM
Quoted: 880 Post(s)
Garage
Sounds like a personal problem.
post #10 of 33 Old 05-26-2019, 01:39 PM Thread Starter
Weberman3's Avatar
Quoted: 634 Post(s)
Got me there
Similar Threads
Thread Thread Starter Forum Replies Last Post
D60 coil spring swap & lift in Excursion drumguy Suspension & Steering 13 08-05-2019 08:10 AM
Need thoughts on best route for coil spring swap KMC_A55 General 6.0L Discussion 2 01-16-2018 04:07 PM
2008-10 axle swap TPlatt 99-03 7.3L Exterior Discussion 11 04-11-2017 06:37 AM
2005 up 4X4 coil spring conversion part #s Houstonvett 99-03 7.3L General Discussion 2 11-10-2016 02:43 PM
