Coolant Change updates? - Page 2 - Ford Powerstroke Diesel Forum
 14Likes
post #11 of 26 Old 05-24-2019, 12:14 PM Thread Starter
twood71's Avatar
Quoted: 67 Post(s)
Originally Posted by SparkyF250 View Post
I would still get it out just because of the silicates, heat makes it form a goo that ends up in the oil cooler.
Yea thats still my plan, with only 30,000 on this engine deleted I wasn't sure on the cascade part. Best to get out the silicates tho I'm seeing.
Again My coolant color is yellow is why I'm not taking a chance with not knowing whats in it.
You gave me quit a bit info, i'm gonna step it together from there and price all this. Appreciate it.
SparkyF250 likes this.
2015 Ford super Duty F-350 SRW 6.7L Power Stroke
2006 Ford Super Duty F-350 DRW 6.0 Power Stroke
twood71 is offline
post #12 of 26 Old 05-24-2019, 04:34 PM
Quoted: 25 Post(s)
Excessive heat in the coolers would break down the coolant. I have my coole=
rs and all of the EGR removed completely and run the Ford crap. Too much tr=
ouble to flush and clean and flush and clean and filter and change the filt=
er and clean some more...blah blah...i did add a filter...thats about it. D=
eleted at 45k miles, temp between oil and coolant at cruise is a delta of 5=
degrees (65 mph) and i am at 153k miles now....dont see an issue w needing=
to go through all that ****. I drain it and completely renew it every 2 yrs
for the last 8 yrs.....and test it too....all good
Sent from my SM-G900V using Tapatalk
mohead1 is offline
post #13 of 26 Old 05-26-2019, 11:15 AM
PowerSmoke07's Avatar
Quoted: 45 Post(s)
Garage
I think mine was in the neighborhood of $200 and I went full and complete chemical flush with Restore and Restore+. Ended up using around 40 gallons of distilled water. The first drain I pulled everything out, block plugs, thermostat, whole 9 yards. Put the Fumoto valves in the block and reassembled. The thermostat didn't go back in until I was completely done. If going this route get concentrate coolant and set aside 3 gallons of distilled water. After all of the flushes there will still be some water left in the system so put the coolant in first and then top off with water to get as close to that 50/50 ratio...DON'T FORGET TO CLOSE THE BLOCK DRAINS
john galt and SparkyF250 like this.
People never have enough time/money to do the job right, but somehow they always find the time/money to do it twice
PowerSmoke07 is offline
post #14 of 26 Old 05-26-2019, 10:29 PM Thread Starter
twood71's Avatar
Quoted: 67 Post(s)
These are the block drains you guys talk about, is the EZ 108 the one that goes behind the starter correct?
Double checking here, so one on each side of the block and these 2 are the ones I should get correct?
ID:	719261   Click image for larger version
twood71 is offline
post #15 of 26 Old 05-27-2019, 11:03 AM
Quoted: 45 Post(s)
Garage
F-108N is what I used on both sides and just put some heavy duty tubing on them and ran them down to right by the sump of the oil pan and put a zip tie to keep them together. I'll see if I can get a pic later.
john galt likes this.
post #16 of 26 Old 05-27-2019, 05:26 PM Thread Starter
twood71's Avatar
Quoted: 67 Post(s)
Yea that help, cant picture that
twood71 is offline
post #17 of 26 Old 05-28-2019, 07:04 AM
Quoted: 45 Post(s)
Garage
post #18 of 26 Old 05-28-2019, 08:14 AM
SparkyF250's Avatar
Quoted: 3348 Post(s)
Garage
I used the Fumotos on both sides with some 3/8 tubing. The EZ with the 90* nipple would prolly work better behind the starter. With those on & some tubing the only mess you'll make is pulling the lower radiator hose, I've never found a way to do that without spillage. Gotta say the 6.0 is better than the 2 piece hose on a 6.4, I've never been able to pull those apart without a coolant bath.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #19 of 26 Old 05-28-2019, 02:02 PM Thread Starter
twood71's Avatar
Quoted: 67 Post(s)
I'm considering 2 fumoto, one for driver block drain and one for the oil pan. Then the EZ behind the starter. Sounds like a plan.
They use dope pipe on threads?
twood71 is offline
post #20 of 26 Old 05-30-2019, 09:48 AM Thread Starter
twood71's Avatar
Quoted: 67 Post(s)
It uses a O ring I see,
twood71 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Has anyone done this with their EGR system Kunkel3269 General 6.0L Discussion 76 03-17-2019 09:58 AM
06 F350 overheat, loss of coolant and steam? TD4200 General 6.0L Discussion 5 12-07-2018 08:57 PM
1997 F250 with coolant in oil, advice appreciated Mrvmax 94-98 7.3L General Powerstroke Discussion 8 05-15-2017 04:30 PM
Ford 6.0 Gold Coolant Change J_For_Justin General 6.0L Discussion 16 11-24-2016 11:30 AM
Coolant change Crosshead 99-03 7.3L General Discussion 20 07-03-2008 01:41 PM
