2007 6.0 f350 coolant smell but no leaks anywhere - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By bismic
post #1 of 8 Old 05-22-2019, 11:25 AM Thread Starter
So, I wanted to see if anyone else has had this problem on their 07 6.0. So I smell coolant after 50 mile highway drive but no leaks anywhere. The reservoir is full to line, plus I just replaced all the hoses, thermostat, reservoir, and cooling temp sensor and did a flush. But it's not overheating or Losing power. So I am really confused no smell coming through vents, it's only when you get out of truck you smell it.
Rgut79 is offline
post #2 of 8 Old 05-22-2019, 01:30 PM
Quoted: 247 Post(s)
The degas cap could possibly be leaking.
Reasons for a cap leaking are:
1. weak cap
2. over-pressured coolant system (head gasket or EGR cooler issue might be the cause in this case)
3. Degas cap sealing surface is rough or not level
It also could be one of the two small coolant lines that go to the degas bottle (vapor space connections)
Hydro likes this.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Bilsteinshocks; BPD EGR cooler;One-piece HPOP fitting;BPDWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #3 of 8 Old 05-22-2019, 03:09 PM
Quoted: 264 Post(s)
Garage
Radiator hose where it connects to the thermostat housing, or possibly the EGR hose in the engine valley are also trouble spots -- doesn't take much coolant to make a smell, you may only see a small leak
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #4 of 8 Old 05-22-2019, 07:48 PM
Quoted: 10 Post(s)
I found a leak on the engine side of my lower hose after a radiator and lower hose replacement. I tightened up the hose clamp and the odor was gone.
Sent from my LG-LS993 using Tapatalk
5J's is offline
post #5 of 8 Old 05-23-2019, 02:54 AM
Old School
Chris's Avatar
Quoted: 27 Post(s)
Garage
I had the same issue and it turned out to be the plastic top cap on the radiator slowly separating from the aluminum radiator body. If you look along the rear side of the black plastic top cap and see some moisture, your radiator is on it's way out. The same thing happened on my 2002 F150. Poor design of the OEM radiator.
2006 Ford F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front and Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit, Morimoto LED Fog Lights, Bilstein 5100s
Chris is offline
post #6 of 8 Old 05-23-2019, 03:13 AM
Old School
Chris's Avatar
Quoted: 27 Post(s)
Garage
This isn't my picture, but I circled the plastic top cap seal I am referring to in red:
Chris is offline
post #7 of 8 Old 05-23-2019, 06:08 AM
Sock Puppet's Avatar
Quoted: 527 Post(s)
Pressure up the cooling system using air so you can look for leaks without the engine running. That was the only way I found mine.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #8 of 8 Old 05-23-2019, 06:20 AM
6.0Castle's Avatar
Quoted: 18 Post(s)
Garage
Two things I got:
If you just replaced your hoses, thermostat, etc. you may have misaligned a clamp when you were re-tightening the hoses. If you don't place the clamps on the same marks it made, a small leak may develop (shout outs to DieselTech Ron, RIP!)
or
Could it be spilled coolant (from the changes) that is slowly burning itself off the hot engine parts?
Frustrating nonetheless...
2004 Excursion
183K and purring, Toyo R/T 285s, 4" Flo Pro, Atlas-40 FCIM tune, SCT X4 with looney, RiffRaff coolant filter/CAC boots, Hewitt/Marshall gauges (Pyro/Turbo/Fuel/EOT/ECT), Nations TAD-185 alternator, Big 3 cable/zoodad mods, Mobile 1, Delo ELC, when does it end?!?
6.0Castle is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
2005 - 2007 F250 F350 Dimensions for Bumper Building -Falcon- FABRICATION FORUM 6 02-16-2019 01:42 PM
6.7 needed new motor at 80k miles. xZxCORE 6.7 Motor Problems (2011-2016) 8 09-28-2016 09:07 AM
Studded 6.0 Pushing Coolant out Degas- Not Headgaskets? 07lariat4x4 6.0 Motor problems 31 09-22-2016 05:48 PM
Check Coolant Additive Dealer Lack of testing LeanderF250 6.7 Problems Forum (2011-2016) 1 08-17-2016 10:42 AM
03 f350 white smoke, losing coolant shawncooke1 6.0L Problems Forum 16 08-10-2016 08:39 AM
