Critique my tuning - please! Haha - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-16-2019, 08:08 PM Thread Starter
How does this look? Took a screenshot since most wont have HPTuners lol. First time tuning a 6.0 in my 2005 f250. I picked at some of the other tunes for 6.0s and this is meant to be a good fun tune, nothing I would tow with I don't think, I'll make a separate tow tune. Right here is where I lay into it pretty good. Atleast from what I've gathered it seems good..maybe add some more inj PW as its only seeing about 1.6? How's everything else look to you guys? Thanks in advance, just trying to learn these trucks.
FYI, my truck is studded, stock inj and stock turbo (as far as I know)
AdamHPC is offline
post #2 of 8 Old 05-16-2019, 08:13 PM
PowerSmoke07's Avatar
Quoted: 43 Post(s)
Garage
I need to learn these powers. Will help me with the racecar too
People never have enough time/money to do the job right, but somehow they always find the time/money to do it twice
PowerSmoke07 is offline
post #3 of 8 Old 05-17-2019, 12:25 AM
Quoted: 247 Post(s)
Is your oil air cooled? Not used to seeing the oil temp below the coolant temp. Looks like your tuner doesn't read the FICM Main Power (MPower). That value should be around 48 volts.
You sure are putting the fuel to it!! Nice system there! Looks like 1.6 FPW is doing well.
I would like to see exhaust gas temperatures!
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Bilsteinshocks; BPD EGR cooler;One-piece HPOP fitting;BPDWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #4 of 8 Old 05-17-2019, 05:40 AM
Fummins Mod
junior125's Avatar
Quoted: 2148 Post(s)
Garage
1.6ms pulse width was what all my tow tunes were with 175/30's, studded hot tunes were more in the 2.2 range
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #5 of 8 Old 05-17-2019, 08:40 AM Thread Starter
Yeah it's the Bulletproof remote oil cooler setup. Every time I've checked temps my oil is either right around coolant temp or a little below.. this log was only after a 15 min drive (havent towed yet, just got the truck recently). I would as well, no EGT gauge yet though
Sent from my SM-G950U using Tapatalk
AdamHPC is offline
post #6 of 8 Old 05-17-2019, 08:41 AM Thread Starter
With stock injectors should I add some pulse width?
AdamHPC is offline
post #7 of 8 Old 05-17-2019, 09:54 AM
Fummins Mod
junior125's Avatar
Garage
you could add some pulse width, I couldn't tell you off the top of my head where they run out of fuel
I would definetly add a pyrometer before pushing it much further, hows your fuel pressure looking?
Mike
2005 CCSB F250 4X4
post #8 of 8 Old 05-17-2019, 12:20 PM Thread Starter
Ok
That's a good question..I havent tested yet but the truck has been heavily fortified (studded, bulletproof remote oil cooler, bulletproof egr, alum radiator, upgraded ic and rad pipes/hoses) so I assume they did the blue spring and it's doing fine but I need to check
AdamHPC is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
How FICM tuning works!! Chatham036 6.0L Performance Parts Discussion 49 01-22-2019 10:32 AM
PPEI vs GDP from Experience (long review) powerstroke1701 6.7 Performance Parts Discussion (2017-2019) 24 01-15-2019 09:15 PM
Where to go to get live tuning, Is it worth it? jmedlin 99-03 7.3L Performance Parts 1 07-30-2018 04:00 AM
H&s mini maxx changing trans tuning? 6.7powerstroker 6.7 Performance Parts Discussion (2011-2016) 1 03-04-2018 08:11 PM
What you REALLY wanted to know about SOI and 7.3L Tuning in general. Power Hungry 99-03 7.3L General Discussion 55 08-28-2017 02:18 PM
