Ebay degas bottle - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 17 Old 05-15-2019, 09:18 AM Thread Starter
Quoted: 38 Post(s)
Ebay degas bottle
Has anybody used one of these??
Ebay degas Bottle
I'm curious about:
1-Is fitting perfect? Screw holes, hose connections, etc...
2- Is the sight glass at the right height according to the revised fill line of the OEM bottle?
GusCO is offline
post #2 of 17 Old 05-15-2019, 11:06 AM
california deplorable
john galt's Avatar
Quoted: 3181 Post(s)
i haven't used one. my biggest question would be the sight window to watch your level and i would absolutely add a gauge to one if i had it as well.
granted the cap should vent as it is a stant cap but...
i have a plastic one from swag performance on flea bay and have no complaints
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #3 of 17 Old 05-15-2019, 11:27 AM
darianmacdonald's Avatar
Quoted: 26 Post(s)
That eBay listing says the seller is Rudy’s? I’d be curious if it’s their own brand degas bottle? I could only find a mishimoto one on their site.
Sent from my iPhone using Tapatalk
2006 CCSB Lariat F-350
304,XXX KM
ARP studs, EGR Delete
SCT SF3 w/ GH & IDP Tunes
BW SXE 62/68/.83AR, Irate T4 Kit
4" Volant Turbo back exhaust
Driven Diesel RR w/ Fuelab Regulator
Isspro Boost, Fuel Pressure, Oil Pressure, HPOP Pressure Gauges
Edge Insight Monitor
FS2500 Oil Bypass Filtration
IDP Tuned 58V FICM
Coolant filtration
R4 Rear Air Ride
Bilstein 5100's
2-Way Compustar Remote Start/Alarm
Misc. mods
darianmacdonald is offline
post #4 of 17 Old 05-15-2019, 12:18 PM Thread Starter
Quoted: 38 Post(s)
The listing is by Rudy's but the pictures look exactly as every other one on e-bay, I just picked this one because it popped up first. It really is just an aluminum tank, no "rocket surgery" here but I was scalded before on simple stuff not fitting where it should.
My bottle is stock but it is cracking, not leaking yet. Although the idea of an aftermarket plastic one is not bad I always like to upgrade whatever needs replacing. I fell like an aluminum one is an upgrade, but I also feel like the brand names are unfortunately too overpriced.
john galt likes this.
GusCO is offline
post #5 of 17 Old 05-15-2019, 12:25 PM
Heavy_GD's Avatar
Quoted: 3170 Post(s)
Garage
Feedback Score: 4 reviews
@ZMANN
john galt and jokester00 like this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #6 of 17 Old 05-15-2019, 01:49 PM
Old School
Chris's Avatar
Quoted: 50 Post(s)
Garage
There are others that appear to be the Chinese knockoff (or original without branding) of Sinister's: https://www.ebay.com/itm/Aluminum-Co...k/192649015314
2006 F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, EGR Delete, South Bend Dual Disc Clutch, AirDog II-4G Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front & Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit and LED Fog Lights, Bilstein 5100s
Chris is offline
post #7 of 17 Old 05-15-2019, 02:19 PM Thread Starter
Quoted: 38 Post(s)
Good point. But at that price I'd rather replace with another OEM
GusCO is offline
post #8 of 17 Old 05-15-2019, 07:52 PM
john galt's Avatar
i got one from swag performance 40 bucks has all the ford markings. for all i know its oem
I like mead
post #9 of 17 Old 05-15-2019, 09:34 PM Thread Starter
Quoted: 38 Post(s)
You convinced me. Got one of those!
GusCO is offline
post #10 of 17 Old 07-08-2019, 08:33 AM Thread Starter
Quoted: 38 Post(s)
Just updating here... The bottle from swag unfortunately was defective. leaking from the seam right out of the box. I am back using my Ford one for now.
GusCO is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Considering buying an 05 6.0 that has a new oil cooler and degas bottle Nevertheless General 6.0L Discussion 3 11-25-2018 12:51 PM
Coolant filter causing degas bottle to puke GOT_ONE 6.0L Performance Parts Discussion 15 10-31-2018 08:16 AM
Degas bottle leaking at cap Mallette 6.4 Motor Problems 67 07-31-2018 04:55 PM
Oil residue in degas bottle Joshua Billman 6.0 Motor problems 3 06-14-2018 02:17 PM
after shop replaced injectors,Overheating, fuel in degas bottle, coolant boiling over redwolf1017 99-03 7.3 Motor Problems 4 06-09-2017 10:18 PM
