Front axle slop? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 Old 05-12-2019, 10:51 AM Thread Starter
Quoted: 17 Post(s)
Front axle slop?
I have an '07 f250 and it needs axle u joints. When I was checking the u joints I noticed the the axles had some slop in the hub. How much play is ok? I assume that one ball bearing is responsible for centering the axle, or does the locking hub act as a second bearing?
Mcflyfyter is offline
post #2 of 25 Old 05-12-2019, 01:20 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 924 Post(s)
Feedback Score: 3 reviews
How much "slop" does yours seem to have??
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 25 Old 05-12-2019, 02:42 PM Thread Starter
Quoted: 17 Post(s)
Maybe 1/4" at the back of the knuckle. The axle to knuckle seals are shot, and I don't want to replace them again if the axle slops around and destroys them.
post #4 of 25 Old 05-12-2019, 03:36 PM
Quoted: 469 Post(s)
Garage
Needle bearings in the hub out?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #5 of 25 Old 05-12-2019, 03:57 PM Thread Starter
Quoted: 17 Post(s)
That is what I thought, but it turns out there is only a single sealed ball bearing. Unless you are speaking of the needle bearing in the locking hub, but I'm not sure if those can be replaced.
post #6 of 25 Old 05-12-2019, 08:36 PM
ZMANN's Avatar
Quoted: 4009 Post(s)
Correct the stub axle uses sealed bearings in the center of the unit bearing on the 05 up the needles were 04 under
the sealed can still fail but not nearly as common as the needle
Hydro likes this.
6.0 flush pdf
ZMANN is offline
post #7 of 25 Old 05-12-2019, 09:17 PM Thread Starter
Quoted: 17 Post(s)
The sealed bearing has zero vertical play, and seems perfectly fine. The auto hubs were so packed with grease that I didn't realize there were needle bearings in them. I'm wondering if the needle bearings went dry and it was packed with grease to avoid buying new hubs. I may just order a new hub and see if that tightens things up a little.
I'm also having a hard time finding the "seal" ring that keeps debris out of the axle tube. Any idea what that is called?
post #8 of 25 Old 05-13-2019, 04:30 AM
066
066's Avatar
Quoted: 10 Post(s)
It's called a dust seal. Ac3z-1s175-a
Also, if you don't have one, a long (3ft+) wrecking pry bar will pry those axle shafts out like nothing.
06 6.0 King Ranch Work Truck
ARP Studs
IPR Remote Oil Cooler
IPR Coolant Filter
KC Stage 2 Turbo
175/30 Injectors + Atlas 40 FICM
BD Up Pipes
Performance Radiator
5" Diamond Eye Exhaust
Gearhead Tunes
HID Retrofit
066 is offline
post #9 of 25 Old 05-14-2019, 09:34 PM Thread Starter
Quoted: 17 Post(s)
That appears to be an upgraded seal, and looks nothing like the remains I have. I was also very surprised how much force it took to dislodge that seal, I had to kick a 3' bar.
post #10 of 25 Old 05-14-2019, 09:38 PM
ZMANN's Avatar
just FYI you can pull a 4x4 auto hub off and drive without issue it is not responsible for supporting the stub shaft in any way
6.0 flush pdf
ZMANN is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Front axle removal issue Bassdo 6.7 Problems Forum (2011-2016) 10 12-29-2018 05:18 PM
What is wrong in this picture? (front axle issue) EskimoPie General 6.7 Discussion (2011-2016) 13 04-04-2017 06:56 PM
Is your front axle centered? OBStrokin General 6.7 Discussion (2011-2016) 9 08-08-2016 08:26 AM
