Front axle slop? - Page 3 - Ford Powerstroke Diesel Forum
 1Likes
post #21 of 25 Old 06-01-2019, 11:28 AM
ZMANN's Avatar
Quoted: 4014 Post(s)
For the record i stand by my statement that the selector hub is not a support bearing for the axle shaft
and you can remove a damaged hub and drive indefinitely
you do not need 3 points of support as suggested for a shaft of this type
6.0 flush pdf
ZMANN is offline
post #22 of 25 Old 06-01-2019, 11:55 AM Thread Starter
Quoted: 17 Post(s)
I believe you are correct. There is some slop that is inherent in the design, that isn't noticed when the seal is good.
Do the new 6.7 trucks use the same setup? It would be interested to give one a shake if they are the same.
Mcflyfyter is offline
post #23 of 25 Old 06-01-2019, 02:00 PM
ZMANN's Avatar
yes the 6.7's are the same setup
they implemented this design is 05 but even the 04 under ESOF /PVH is similar
if you ever grenade a selector hub you can remove them and tape over the hole ( but you will loose 4x4 of course)
6.0 flush pdf
ZMANN is offline
post #24 of 25 Old 06-01-2019, 02:10 PM
partyman97_3's Avatar
Quoted: 907 Post(s)
Garage
Hey @Mcflyfyter , not really adding to the thread, but the following website has a ton of information on it. Probably more than most of need, but you seem to be the inquisitive type.
https://venturestruckparts.com/
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #25 of 25 Old 06-01-2019, 04:32 PM Thread Starter
Quoted: 17 Post(s)
Just stopped by the scrap yard, and the brand new trucks have a ton of slop too. Looks like it just needs u joints and seals.
Apparently nobody here has actually put 2 hands on their axle and checked for slop?
Similar Threads
Thread Thread Starter Forum Replies Last Post
Front axle removal issue Bassdo 6.7 Problems Forum (2011-2016) 10 12-29-2018 05:18 PM
What is wrong in this picture? (front axle issue) EskimoPie General 6.7 Discussion (2011-2016) 13 04-04-2017 06:56 PM
Is your front axle centered? OBStrokin General 6.7 Discussion (2011-2016) 9 08-08-2016 08:26 AM
