Turbo Whistle - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 16 Old 05-11-2019, 05:04 AM Thread Starter
Graysen's Avatar
Turbo Whistle
Hey guys so I just installed a KC stage 2, owdog intake and 4" turbo back straight pipe MBRP. Anyone else with this set up, is your turbo whistle ear piercing? Not bad at idle but if she high idles you cant stand close to end of pipe.
HeavyAssault likes this.
Graysen is offline
post #2 of 16 Old 05-11-2019, 11:43 AM
darianmacdonald's Avatar
Quoted: 26 Post(s)
A KC stage 2 paired with a straight pipe will definitely be loud that’s for sure. Nothing out of the ordinary there.
Sent from my iPhone using Tapatalk
HeavyAssault and jokester00 like this.
2006 CCSB Lariat F-350
304,XXX KM
ARP studs, EGR Delete
SCT SF3 w/ GH & IDP Tunes
BW SXE 62/68/.83AR, Irate T4 Kit
4" Volant Turbo back exhaust
Driven Diesel RR w/ Fuelab Regulator
Isspro Boost, Fuel Pressure, Oil Pressure, HPOP Pressure Gauges
Edge Insight Monitor
FS2500 Oil Bypass Filtration
IDP Tuned 58V FICM
Coolant filtration
R4 Rear Air Ride
Bilstein 5100's
2-Way Compustar Remote Start/Alarm
Misc. mods
darianmacdonald is offline
post #3 of 16 Old 05-11-2019, 12:57 PM
PowerSmoke07's Avatar
Quoted: 45 Post(s)
Garage
Majority of the upgrade turbos do that. My neighbor said that when I first moved in he got flashbacks to being on the flight deck of a carrier when I would start my truck. Garrett Powermax, 4" downpipe and about 3' of 4" straight pipe before it turns out the side
People never have enough time/money to do the job right, but somehow they always find the time/money to do it twice
PowerSmoke07 is offline
post #4 of 16 Old 05-11-2019, 01:01 PM
doubleslottedflaps's Avatar
Quoted: 190 Post(s)
my 06 with stock turbo no tunes has had a Hog Performance brand 4" turbo back no cat no muffler since new. stand at the end of the exhaust pipe and it sounds like a jet engine and is loud and high pitch and its still loud across the street.
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #5 of 16 Old 05-12-2019, 04:50 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 928 Post(s)
Feedback Score: 3 reviews
I loved my 2006 P-max whistle.....as above quite loud but it's what I wanted. Wish my 6.7L could get that high pitched whistle.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #6 of 16 Old 05-12-2019, 08:10 AM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1683 Post(s)
Garage
I also have a 10 vane KC and yea I agree with OP that turbo pitch was crazy loud. It bounced off of fence posts on barb wire fences.
No joke, I rolled down my D/S window and heard it bouncing off the passing cars on roads.
I liked the sound but not at the level with no cat or muffler.
I had a 4” Corsa muffler and it did nothing.
My solution was a:
Diamond Eye 4” muffler
Magnaflow 4” together.
Both are SS and straight thru packing type mufflers.
I still have a whistle sound but very subtle. I do like it and 0% power loss.
Good Luck on it. Honestly one muffler would likely been enuf but I bought the Diamond Eye and was given Magnaflow. I wanted to snip it in the bud so I just slapped on both.
Enjoy
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3” CAC Pipes & CSF 7106 I.C.
4” Diamond Eye SS Exh System
W/two 4” SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #7 of 16 Old 05-12-2019, 08:41 AM
fetorino's Avatar
Quoted: 35 Post(s)
I have some hearing loss anyway so just to help out the OP I’ll swap my stock intake and Turbo with him. 😜
Mine is not a stage II but I do run a 10 blade through a 4” stainless downpipe to 5” tubing to a stack. I am running an FTE resonator and the results are excellent. Lots of whistle sound but no drone or piercing shriek. Also make sure the exhaust is well anchored as a loose exhaust adds resonance that makes the problem worse.
mhatlen likes this.
04 F450
Studded 6.0 PSD backed by a Torqueshift
Dually Flatbed gooseneck hauler
BPD 7.3 fan clutch adapter
Sinister Bypass and coolant filters
Blue spring upgrade
Rotella T6
Ford Gold coolant
Magnaflow 4" downpipe FTE 4"in 5" out resonator to stack
FICM fixer rebuild and stock reflash
PHP 25hp heavy tow PCM flash
fetorino is offline
post #8 of 16 Old 05-12-2019, 09:36 AM
Quoted: 45 Post(s)
Garage
^ This 150%! Also be mindful that a 4" downpipe is a tight fit and you will have maybe 1/4" on either side where it comes down between the firewall and transmission (at least on a ZF-6) and if it makes contact with the body or the transmission the vibration will drive you nucking futs...ask me how I know
post #9 of 16 Old 05-12-2019, 10:03 AM
2008 6.4 egr deleted, almost 200,000 miles...
original turbo started whistling....installed an AFE Bladerunner....it whistles and hisses at the same place. actuator arm.
Before I swap the turbo AGAIN...
I am thinking some parts of the exhaust may be clogged. My dpf was supposed to be hollowed out somewhat, 30,000 miles back and stopped regen at that time.
Would like to hear opinions on this, please. The turbo swap was not easy.
Could the DPF or Cat or muffler be clogged and could it produce this symptom?
I see the DPF deletes on ebay, don't really want LOUD...guess I have to use a muffler in there. Would love some advice.
Thanks Guys
JC
johncasey377 is offline
post #10 of 16 Old 05-12-2019, 07:28 PM Thread Starter
Graysen's Avatar
Thanks for everyone's input I just wanted to make sure was not just my truck. Yeah that down pipe is a pain it keeps shifting around on me. I love the whistle but also thinking about adding muffler or resonator just to take the edge off especially when truck is in my shop, feels like its piercing my soul lol.
Graysen is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
vgt no idle turbo whistle BKB94 6.0L Problems Forum 10 03-23-2019 11:13 PM
Turbo, VGT, something else?? jokester00 6.0L Problems Forum 49 03-16-2018 09:08 PM
Turbo whistle? Jokersace General 6.0L Discussion 19 11-06-2017 01:18 PM
Turbo Surging..please help thaemcee2 6.0 Motor problems 3 05-06-2017 10:17 PM
New turbo setup review (it's about time) Austen 99-03 7.3L General Discussion 13 02-12-2017 01:35 AM
