6.0 Cold Rough Idle with 8 new Injectors - Page 2 - Ford Powerstroke Diesel Forum
 11Likes
post #11 of 22 Old 05-07-2019, 06:46 PM
Got Dirt?'s Avatar
Quoted: 163 Post(s)
Garage
Originally Posted by H500D View Post
Curious, I'm going through old threads on Dashboard, Dashboss and Torque Pro.... I'm curious if I can get a setup for EGT and fuel pressure for Dashboard? I see that Dashboss has the capability but it is sold out and kind of expensive. It is almost as if gauges are a thing of the past. What is the consensus on this these days?
I did test my ficm and the voltage was low. I changed it out and it seems much better but I still have a slight stumble/miss on the first start of the day but it is not as severe and not as long. Im looking forward to be able to test what else is going on.
Take a look at the Edge CTS2 with EGT probe and Fuel Pressure Sensor. Your prob sounds like it could be low fuel pressure.
"Life is a Garden - Dig It!!!" ~ Joe Dirt
"Rub Some Dirt On It!!!"
"God Made Dirt, Dirt Don't Hurt!!!"
2006 Super Duty F-250 Lariat CCSB: Edge CTS Insight - BPD FICM - Sinister Diesel Coolant Filter - ProComp 20" wheels - Toyo M/T 35's - ReadyLift w/ Bilstein 5100's - 4" MagnaFlow Exhaust
Got Dirt? is offline
post #12 of 22 Old 05-08-2019, 12:17 PM Thread Starter
H500D's Avatar
I got some data... any suggestions to add to the Dashcmd data? Still working on a way to see fuel pressure.
Got Dirt? likes this.
H500D is offline
post #13 of 22 Old 05-10-2019, 08:53 AM
If your route is I-90, Rocky Mountain Diesel in Missoula is great. They're also right off the Interstate off the reserve exit. I know of a lot of businesses come over from Spokane to have their vehicles taken care of.
Sent from my XT1650 using Tapatalk
wanrus 06 shaker is offline
The Following User Says Thank You to wanrus 06 shaker For This Useful Post:
H500D (05-13-2019)
post #14 of 22 Old 05-10-2019, 09:45 AM
Quoted: 2 Post(s)
I had similar issues but mine was a combination of unfortunate events that I just did a write up on. My IPR harness melted and was creating an intermittent short. I went through the entire fuel system from engine back replaced filters, took my HFCM completely apart, new fpr spring, purged the lines with compressed air from the HFCM hoses to the tank and then forward to the fuel bowl.
Turned out being this guy the whole time:
Has your STC been changed?
I was thinking I was chasing a fuel issue when it was an electronic and HPO control issue all along.
ID:	718549   Click image for larger version
Stroker Ace 04 is offline
post #15 of 22 Old 05-10-2019, 10:02 AM
Quoted: 2 Post(s)
Originally Posted by bismic View Post
You really need a way to look at engine parameters ...... Otherwise take it in.
It could be the EGR (if you still have it), or the FICM or the ICP .... as others have mentioned.
Get data, don't guess!
I called IPR about parts a couple days ago and got those exact words. I ended up buying an Insight rather than what I originally called looking for. Awesome experience and honest conversation got the point across that I needed to know more about what’s going on that just coolant temps.
post #16 of 22 Old 05-12-2019, 08:29 AM
PowerSmoke07's Avatar
Quoted: 44 Post(s)
Garage
Do you still have your old injectors or did you send them in as cores? Trying to get my hands on another set to rebuild and have on the shelf for when mine start acting up.
People never have enough time/money to do the job right, but somehow they always find the time/money to do it twice
PowerSmoke07 is offline
post #17 of 22 Old 05-13-2019, 08:45 AM Thread Starter
H500D's Avatar
I think everything is looking really good with what I can see in Forscan - but I still need a way to check fuel. I'm going through the fuel system this week and check the pressure and install a new blue spring kit and recheck (mine was done 75,000 miles ago). One thing sticking out in my mind is how the o-rings looked like they were being sucked off the injectors. I'm going to drop the fuel tank, clean it out, clean the tank screens and maybe install a new HFCM or aftermarket pump and sump. It is going to suck but after 100,000 miles it is probably time and there is nothing left to change. I'm not driving it until the fuel system is sorted out.
Curious, does anyone believe in the 6.4 banjo bolt upgrade for the 6.0?
Sorry Powersmoke07, but the injector cores went in...
H500D is offline
post #18 of 22 Old 05-13-2019, 10:14 AM
Quoted: 44 Post(s)
Garage
No worries.
I've got 6.4 banjos, Idk that they make a difference, I put them on like 10 years ago...which reminds me, like you my fuel spring is probably getting due for a new one, 75k on mine as well
post #19 of 22 Old 05-13-2019, 07:27 PM
Quoted: 264 Post(s)
Garage
The 6.4 banjos do not have the checked orifice in them like the originals do -- the check is in there to keep pulsing vibration out of the fuel system -- will this change hurt the injectors? not sure, but the Engineers thought the check valve was a good idea
That said, the check valve will wear over time and either stick or leak back too much fluid -- replacing likely a good idea
The fuel regulator valve will wear as well and cause low fuel pressure / leaking back to tank issues
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #20 of 22 Old 05-13-2019, 10:11 PM
california deplorable
john galt's Avatar
Quoted: 3026 Post(s)
if you can swing it the new adjustable bule spring is a pretty sweet add on so you can keep fp in range...75k on mine now too now that i think about it
but it still hangs at 62 to 64 and only drops to 55 at wfo with 4,000# of hpo up hill
but i am about due
one thing i notice and i am sorry that i do not have more experience with my ficm i have had 2 rebuilt but thats about it but your ficm logic being at 24 volts?
i thought i read somewhere and probably a couple years ago so pardon the quetionable memory
but shouldnt the logic side not be over like 12.5 or 13 volts?
and again i could be wrong but it seems i read that in here somewhere maybe 3 years ago now
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Semi Random Rough Idle wyowolf General 6.0L Discussion 1 01-11-2019 04:18 AM
Rough idle??? markm7273 94-98 7.3L General Powerstroke Discussion 5 10-20-2018 08:07 PM
Running rough / missing when cold, ideas? Red Ford General 6.0L Discussion 4 04-15-2018 03:48 PM
Rough Idle Lsears0013 99-03 7.3 Motor Problems 38 08-23-2016 05:16 PM
03 6.0L start up idle speed / smoke / injectors. rondon600 6.0 Motor problems 1 03-08-2006 07:47 PM
