Late build 04 vs 05-10 glow plug harness question - Ford Powerstroke Diesel Forum
 24Likes
post #1 of 13 Old 04-26-2019, 07:32 AM Thread Starter
SkullsMN's Avatar
Quoted: 2 Post(s)
I am getting ready to replace my glow plugs. I’m pretty sure I have a late 04 built motor. Sticker is gone on valve cover but I do have the ICP sensor in the cover near the alternator.
First question, do people usually replace the harness every time they put in new glow plugs.
Second? Will a harness for a 05 work on my truck? Amazon has a set of Motorcraft OEM harnesses but the description says 2005-2010. Will these work?
SkullsMN is offline
post #2 of 13 Old 04-28-2019, 06:43 PM
HP MACHINE's Avatar
Quoted: 479 Post(s)
I'm pretty sure your ok with the later harnesses . I own a late build 04' ( march 04 ' ) and I used the 05-07 part # . Like you
mentioned , the icp at the front of the passenger side valve cover is the tell all between early and late .
You're probably going to wreck the old harness getting them off to change the plugs , so it's not a bad idea to have new ones on hand .
@djmaguire knows this stuff like the back of his hand , maybe He can confirm .
john galt likes this.
HP MACHINE is offline
post #3 of 13 Old 04-28-2019, 06:47 PM Thread Starter
SkullsMN's Avatar
Quoted: 2 Post(s)
Good to know. I will order the harness along with the glow plugs. Had no idea it would wreck the harness.
Thank you so much for your help.
Sent from my iPhone using Tapatalk
SkullsMN is offline
post #4 of 13 Old 04-28-2019, 06:51 PM
ChrisSki's Avatar
Quoted: 550 Post(s)
There is a glow plug harness remover special tool, or you can fab one. That is more if the one you put on needs to come off later. The 14 year old harness probably won't stand being removed.
SkullsMN likes this.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #5 of 13 Old 04-28-2019, 06:56 PM
djmaguire's Avatar
Quoted: 1586 Post(s)
Garage
Originally Posted by SkullsMN View Post
First question, do people usually replace the harness every time they put in new glow plugs. ...
I would. They aren't that expensive and they are riding in nasty heat. That's in addition to what @HP MACHINE said.
... Second? Will a harness for a 05 work on my truck? Amazon has a set of Motorcraft OEM harnesses but the description says 2005-2010. Will these work?
[Incorrect statement removed]
PLEASE JUMP DOWN A FEW POSTS TO @bismic 's POST BELOW.
It's here (for the really lazy!):
https://www.powerstroke.org/forum/ge...l#post16277353
He knows everything there is to know about GP harnesses.
I'm guessing that the 200X-2010 range is because the 6.0 was used in vans through 2010.
The only big big deal with glowplugs is not sticking early model glowplugs in a late model engine. They are longer and one revolution is all it takes.
You are too kind.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #6 of 13 Old 04-28-2019, 07:20 PM
HP MACHINE's Avatar
Quoted: 479 Post(s)
Yes. There is only early and late. 2005+ means 2004.5+. I'm guessing that the 200X-2010 range is because the 6.0 was used in vans through 2010.
You are too kind.
More like Grateful . You've helped many of us . Thank you .
post #7 of 13 Old 04-28-2019, 08:21 PM
california deplorable
john galt's Avatar
Quoted: 3104 Post(s)
You are too kind.
i wondered about that i was thinking the 6.4 08-10 ight use the same glow plug harness? seems like i read that someplace but
seems more certain that the 6.0 was used in vans up to 2010 i had forgotten that
and DJ there are good reasons why you are the librarian or "orgcyclopedia" but you got the links to every needed bit of info on these trucks man i dont know if you realize how truly impressive and useful that vast wealth of knowledge is
bismic, HP MACHINE and djmaguire like this.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #8 of 13 Old 04-29-2019, 02:57 AM
Quoted: 300 Post(s)
Just a little detail on the harness mess when it comes to part numbers (there actually are early, mid, and late part numbers when it comes to glow plug harnesses)-
The EARLY 2004 build date is earlier than September 29th, 2003, you should consider yourself the owner of a 2003 truck, when it comes to ordering any and all engine parts:
Passengers (right) side GLOW PLUG BUSS BAR - 3C3Z-12A690-BA
Drivers (left) side GLOW PLUG BUSS BAR - 3C3Z-12A690-AA
Engine Harness # 3C3Z-12B637-BA (Navistar ID# 1843797C93)
For 2004:
Look at your ICP sensor on the passenger side valve cover. Pay attention to how the GPCM is bolted up to the bracket that secures to the valve cover. If you happen to have it secured in a manner similar to a 2003 engine (HORIZONTAL ORIENTATION), you have a mid/late build 2004 engine (FROM 08/17/03 to 01/15/0). As such, your engine uses glow plug harnesses part numbers 4C3Z-12A690-AA (Navistar ID# 1845915C9) right side, and 4C3Z-12A690-BA (Navistar ID# 1845793C9) left side (engine harness Ford part number 4C3Z-12B637-AA (Navistar ID# 1844262C93))
If you have your GPCM mounted on the bracket, identically to the way it is on 2005 and later engines (VERITCAL ORIENTATION), you have a late/late build 2004 engine (04 AFTER 1/15/04). As such, your engine use glow plug harness Ford part numbers 4C2Z-12A690-AB (Navistar ID# 1845794 C9) right side, and 4C2Z-12A690-BA (Navistar ID# 1845695 C9). Notice, the right side glow plug harness part number is also identical to that, that is used on '05 and later engines (engine harness Ford part number 4C3Z-12B637-CA (Navistar ID# 1846377C92))
For 2005 and up the drivers side is a different part number:
Drivers (left) side 5C3Z-12A690-A
Passenger (right) side 4C2Z-12A690-AB - note it is the same as the late 04
Early build 2005 Engine Harness F-Series (EBP mounted to T-Stat housing) - 5C3Z-12B637-AA
Another Engine Harness: '05 to '07 F series
This harness will fit 03 and 04 engines also. It comes with routing instructions - 5C3Z-9D930-A
Engine Harness: 2010 E series - 6C2Z-12B637-U
bismic is online now
The Following 5 Users Say Thank You to bismic For This Useful Post:
ChrisSki (04-29-2019), djmaguire (04-29-2019), john galt (04-29-2019), SkullsMN (04-29-2019), TooManyToys (04-29-2019)
post #9 of 13 Old 04-29-2019, 07:43 AM
djmaguire's Avatar
Garage
Originally Posted by bismic View Post
Just a little detail on the harness mess when it comes to part numbers ...
Sorry guys. I didn't know about the one in the middle. I'm going to edit my post above to refer everyone down here so that someone doesn't stop at my post and end up not knowing the scoop. Thanks Mark!
bismic, john galt and SkullsMN like this.
2004 F550 CC Lariat
The Following User Says Thank You to djmaguire For This Useful Post:
post #10 of 13 Old 04-29-2019, 11:26 AM
john galt's Avatar
i LOVE this place
i can think of no better location to track down info like that
thanks you guys
and just a reminder
I like mead
Similar Threads
Thread Thread Starter Forum Replies Last Post
6.0 Harness Chafing djmaguire 6.0 Motor problems 16 06-08-2019 12:58 AM
GLOW PLUG PROBLEMS mwoolard1912 6.0 Motor problems 8 03-06-2019 07:55 AM
P06BA Glow Plug #2 Failure rogue909 6.7 Motor Problems (2011-2016) 4 06-11-2018 07:00 PM
6.0 Parts List By FORD/INTERNATIONAL roche837 General 6.0L Discussion 281 05-25-2017 03:56 PM
230 amp alt, ran new 2 GA wire to batt, now i have a glow plug relay wiring question funfords 99-03 7.3L Powerstroke Problems 7 12-25-2016 10:32 PM
