new to the forum - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-22-2019, 02:41 PM Thread Starter
firestarter88's Avatar
new to the forum
Hello all, Im new to the forum. Just bought an 06 250. 6.0 with 123,600 miles on it.
Bought it from my neighbor and he took good care of it. I bought the truck with the intention of pulling a trailer for my junk removal business. And im wondering what upgrades i need to do right away. i bought airbags and will be installing them this weekend. Im aware of some of the infamous problems with the 6.0. This truck doesn't have an egr delete but runs great as is, although i know this wont last. Do i need to replace it right away or wait? Any other upgrades that need to be done asap please let me know. Thanks for reading. Pics on the way
firestarter88 is offline
post #2 of 4 Old 04-23-2019, 05:57 AM
ChrisSki's Avatar
Quoted: 506 Post(s)
Honestly, take a couple of weeks and get to know the truck. If it drives good, why fix what's not broken. There's some basics, like perhaps an oil change. Some will tell you change the coolant to CAT -1 ELC, but its been in there a while, and a poorly done fluid change will lead to a clogged oil cooler, which is expensive and time consuming to fix. If you choose to do it, plan the change well. IMO heads and studs are done when the heads go bad.
Welcome.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #3 of 4 Old 04-23-2019, 02:44 PM
Quoted: 235 Post(s)
I am one that would recommend switching to an EC-1 rated coolant if it is still on Ford Gold. HOWEVER, you need a monitor to look at your temperatures (oil and coolant) first! If the oil cooler is getting clogged up, you should flush the coolant one way (back flush oil cooler and maybe use chemical cleaners). If it isn't clogged up, you can flush it another way.
Make sure you aren't getting ANY oil in the coolant!
Make sure you are using ONLY OEM filters (and that the oil filter cap is OEM also).
Don't ignore batteries and alternator or you will be spending money on a FICM.
At some point a fuel pressure sensor and gauge is wise. Expensive injectors need at least 50 psig fuel pressure at all times.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Bilsteinshocks; BPD EGR cooler;One-piece HPOP fitting;BPDWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #4 of 4 Old 04-24-2019, 10:31 AM Thread Starter
Thanks for the feedback. I really appreciate it. I'm wondering if this truck will be ok to tow 14k dump trailer???....I used it this morning and I may have overloaded it but it pulled it just fine, a little slow but it was ok.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gates Rad hoses & Belt NoRalPh 99-03 7.3L General Discussion 19 07-07-2017 05:17 PM
Forum not as active as I remember? anschutz1913 General 6.0L Discussion 44 08-17-2016 07:07 AM
New To The Forum strokermann Introductions 10 11-11-2006 05:59 AM
