Glowplug cause #8 contribution? - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 20 Old 04-21-2019, 03:58 PM Thread Starter
Quoted: 3 Post(s)
Im looking at an '06 with 138k, and everything looks good except a p0678 and p0284. It lost the front driveline 2 months ago, along with half of the transfer case. It hadn't been started since it broke, but it fire up easily with a fair amount of white smoke. It idled kinda rough for a minute or so, and the smoke cleared up after 5 minutes.
Only mods I know of are egr delete a tune. Claims new injectors and glow plugs recently. How bad could I really get hurt for $3k?
Thanks for any help!
Mcflyfyter is offline
post #2 of 20 Old 04-21-2019, 07:48 PM Thread Starter
Quoted: 3 Post(s)
Well, I was finally able to get ahold of the only ford tech I know. He said it was likely that zero degree weather when it was last driven that the contribution code was caused by the glow plug or controller. He said to find a round single pin connector between the battery and the hvac plenum, and short the pin to hot to crank without fuel. If it has an even and steady sound it should be ok on compression. Check blowby at the cap for excessive or uneven pulses.
Anyone have any thoughts to add?
For some reason I look at a powerstroke and go full retard. Having only owned 5.9's it just seems like double the trouble, but I'm not sure if that thought is justifiable. Not knowing what anything is, really throws me off though. I can't believe I didn't even check blowby when I looked at it the first time.
post #3 of 20 Old 04-22-2019, 02:59 AM
066
066's Avatar
Quoted: 7 Post(s)
youtube. com/watch?v=yK8-ULtrjY4
The base engine check starts at around 7 minutes in. A glow plug won't cause contribution issues.
You're going to be looking at an injector, FICM, or compression problem.
twoicebergs likes this.
06 6.0 King Ranch Work Truck
ARP Studs
IPR Remote Oil Cooler
IPR Coolant Filter
KC Stage 2 Turbo
BD Up Pipes
Performance Radiator
5" Diamond Eye Exhaust
Gearhead SRL+
HID Retrofit
066 is online now
post #4 of 20 Old 04-22-2019, 05:19 AM Thread Starter
Quoted: 3 Post(s)
Where can I find the set parameters for a contribution code? Is there a fsm download available?
post #5 of 20 Old 04-22-2019, 10:10 AM Thread Starter
Quoted: 3 Post(s)
I could only find a 3 minute video searching that link.
Are you saying that it will ignore any imbalance until the engine reaches operating temp?
post #6 of 20 Old 04-23-2019, 04:41 AM
066
066's Avatar
Quoted: 7 Post(s)
youtube. com/watch?v=xbKZ50x4_go
Sorry, I copied the wrong video link. Watch the whole thing, it will help you out if you're serious about this truck.
At 11:15 minutes, he pulls a P0284 code on his scanner. The description on the right says possible causes are: Valve train assembly, Fuel injector, or compression rings.
ARP Studs
IPR Coolant Filter
KC Stage 2 Turbo
BD Up Pipes
Gearhead SRL+
HID Retrofit
066 is online now
post #7 of 20 Old 04-25-2019, 01:26 PM
MrOneEyedBoh's Avatar
Quoted: 27 Post(s)
Feedback Score: 11 reviews
Just wanted to say, Id point at a bad powerside FICM. I have one for sale if you need one, its damn near brand new. I cant send you any PMs tho, so I guess let me know here.
MrOneEyedBoh is offline
post #8 of 20 Old 04-25-2019, 01:53 PM Thread Starter
Quoted: 3 Post(s)
Is voltage the only way to diagnose a bad ficm, or will the koeo injector test help. I did the injector test, but being ignorant to powerstrokes, I didn't know what I should have been listening for.
post #9 of 20 Old 04-25-2019, 02:02 PM
Quoted: 27 Post(s)
Honestly what Ive found and suggest is to test them cranking and under a load.. they can look good under idle but once a load is applied and the ficm is required to work harder etc, thats when it can show fault.
post #10 of 20 Old 04-27-2019, 01:08 PM Thread Starter
Quoted: 3 Post(s)
How does this look? I couldn't detect pulses with my hand, and a piece of paper on the neck didn't flutter much at all. It idles fine, and is smooth up to 1900rpm, then it starts getting pretty rough. A fuel line an the frame is half smashed, but I doubt it is enough to starve for fuel without a load. There was a fair amount of smoke until it warmed up, then just a slight haze.
https://youtu.be/VpmwKXo9JZM
Similar Threads
Thread Thread Starter Forum Replies Last Post
Random cylinder contribution balance fault Tjn1994 6.0 Motor problems 17 07-17-2018 12:28 PM
06 F250 Cyls 2,4,6,8 Weak contribution, rough running beeker 6.0L Problems Forum 7 04-27-2018 07:04 AM
P2063....Injector? HPOP? Canucktony 6.0 Motor problems 6 08-03-2017 11:59 AM
Cylinder Contribution GearSlammer 6.0 Motor problems 4 03-17-2017 12:35 PM
contribution codes jumping around Dirtyduty General Diesel Discussion 0 07-25-2016 08:12 AM
