Another numbers question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-20-2019, 05:12 AM Thread Starter
tmj690's Avatar
Quoted: 6 Post(s)
Silly I know but, what is considered Max boost from a stock turbo? Iím not having issues(that I know of, but could change after reading replies). Iíve seen 26-28 psi, which comes on very quickly when needed, and holds until I back off or as the truck comes up to speed.
Another FICM question. Mine is always between 47.5-48.5, mostly 48-48.5 while driving. It drop to 47.5 from time to time, but not for long. Should the voltage go up and down or should it remain constant?
tmj690 is offline
post #2 of 5 Old 04-20-2019, 06:45 AM
kcoyner's Avatar
Quoted: 190 Post(s)
It's been a while since I had a stock turbo but I'm sure I never saw 30 in any WOT run. The FICM voltage will not be constant. If you start seeing lower numbers, start looking at FICM options quickly before you loose an injector.
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #3 of 5 Old 04-20-2019, 09:14 AM
Sock Puppet's Avatar
Quoted: 521 Post(s)
26-28 is muy bueno.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #4 of 5 Old 04-21-2019, 06:44 PM
Quoted: 31 Post(s)
Mine gets 24 tops. All stock. I got it apart today and it looks like I had some exhaust leak I was not aware of...
Sent from my iPhone using Tapatalk
GusCO is offline
post #5 of 5 Old 04-26-2019, 07:14 AM
Max Boost
Max boost I have ever saw was about 27.5. This is all stock unloaded flat ground.
semperstrokin is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Engine serial numbers and IPR question Zach Walker 94-98 7.3L General Powerstroke Discussion 1 04-10-2019 02:22 PM
Help Needed Deciphering Torque Pro Numbers Got Dirt? General 6.0L Discussion 4 06-15-2017 08:37 AM
Front Suspension Part Numbers Inside Cajundude 6.4 Drivetrain Problems 8 02-05-2017 05:52 AM
HPOP numbers with new AC code injectors coloF350 94-98 7.3L Performance Parts 8 01-04-2017 04:39 PM
HPOP numbers with new AC code injectors coloF350 99-03 7.3L Powerstroke Problems 2 12-31-2016 09:51 AM
