Blown intercooler?? - Ford Powerstroke Diesel Forum
 27Likes
post #1 of 17 Old 04-12-2019, 03:09 PM Thread Starter
027.3's Avatar
Quoted: 5 Post(s)
Blown intercooler??
I was driving home from work today when all of a sudden while accelerating from a light I heard a huge whooosh come out from under the hood and lost boost. It still drives but when it gets to around 15-20 psi I can hear it leaking out from somewhere, of course the more it tries to build boost the louder it gets. I pulled the metal charge pipe and checked the coupling hoses and they both are in great shape with no cracks or holes. Could it be coming from the intercooler itself?? It’s absolutely completely stock ‘05 6.0 with 98,000mi.
'02 7.3 4 door 4X4 -- Leveled, WIcked wheel,4" turbo back w/ 5" tip, 6637, foil delete, zoodad mod, hutch/Harpoon mod, glow shift Egt & boost, 4- 7" 55w HIDs
027.3 is offline
post #2 of 17 Old 04-12-2019, 04:06 PM
kcoyner's Avatar
Quoted: 184 Post(s)
It could be but it's not likely. I'm betting it's one of the boots. When you build enough boost it's probably escaping around a clamp somewhere.
k
jokester00 likes this.
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #3 of 17 Old 04-12-2019, 05:04 PM
G8orFord's Avatar
Quoted: 2399 Post(s)
Garage
Split cold side plastic pipe. Probably at the lower end. < most likely IMO
Could be a leak at the plastic tanks on the intercooler too.
Could be a hot side boot
Could be something else.
john galt, jokester00 and Chris like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #4 of 17 Old 04-12-2019, 05:14 PM Thread Starter
027.3's Avatar
Quoted: 5 Post(s)
I’m going to check the cold side in the morning. I took the hot side off and everything looked good with no holes or cracks in the pipe or boots. I’m just hoping it not the actual intercooler itself.
027.3 is offline
post #5 of 17 Old 04-12-2019, 08:18 PM
jokester00's Avatar
Quoted: 396 Post(s)
Garage
If it's the cold side, your best bet is to upgrade to the metal one. However, if you don't want to do that, I have a plastic one sitting in my garage doing nothing from when I upgraded that I would sell ya a heck of a lot cheaper than anywhere else.
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
post #6 of 17 Old 04-13-2019, 05:53 AM
ChrisSki's Avatar
Quoted: 485 Post(s)
If you get a 4" rubber cap and air compressor connections, you can charge up to 10 PSI and find the leak real quick. DieselSite sells them, or it is something if you're handy you might be able to build yourself at home depot.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #7 of 17 Old 04-13-2019, 11:57 AM Thread Starter
027.3's Avatar
Quoted: 5 Post(s)
Pulled the cold side off and there’s a small crack by the intercooler. Looks like I’m upgrading.
027.3 is offline
post #8 of 17 Old Today, 03:26 AM
Old School
Chris's Avatar
Quoted: 24 Post(s)
Garage
Same thing happened to me. I have an extra brand new Spearco cold side metal pipe and boots in my garage I am willing to sell for cheap if you're interested. PM me if you are.
2006 Ford F250 CCSB FX4 6 Speed Manual
KC Stage 1 Turbo, Spearco Intercooler, SCT X4 w/ Custom TSD Tunes, ARP Studs, South Bend Dual Disc Clutch, AirDog II-4G Fuel Pump, AFE HD Momentum CAI, AFE CAC Pipes, AFE Intake Horn, AFE Front and Rear Dif Covers, Magnaflow 4" Turbo Back, EGR Delete, Sinister 200 Amp Alternator, Sinister Coolant Filter, BPD Radiator, BPD Water Pump, Big 3 Upgrade, Blue Spring, EDGE Insight CTS2, Morimoto BI-LED Projector Retrofit, Morimoto LED Fog Lights, Bilstein 5100s
Chris is offline
post #9 of 17 Old Today, 06:36 AM Thread Starter
027.3's Avatar
Quoted: 5 Post(s)
Thanks man but I’ve already got one coming from riffraff.
027.3 is offline
post #10 of 17 Old Today, 07:54 AM
california deplorable
john galt's Avatar
Quoted: 2964 Post(s)
was going to say this then saw you had a 7.3
obviously i am late to the party and can offer o further assistance...
BUT...
is this an 02 or 05-07 we are talking about here and i missed something
i need more coffee
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mishimoto’s 2011-2016 6.7L Powerstroke Intercooler R&D Thread Mishimoto 6.7 Performance Parts Discussion (2011-2016) 57 Yesterday 02:48 AM
Mishimoto R&D: Ford 6.7L Powerstroke Air-to-Water Intercooler Mishimoto 6.7 Performance Parts Discussion (2017-2019) 2 11-20-2018 05:47 AM
Blown intercooler Hose jdog8139 General 6.7 Discussion (2011-2016) 10 08-03-2017 05:59 AM
Blown Intercooler fuegonaz General 6.0L Discussion 10 10-21-2016 02:59 PM
