Fuel treatment? - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 15 Old 03-25-2019, 02:49 PM Thread Starter
wiredgeorge's Avatar
Quoted: 3 Post(s)
Fuel treatment?
PO used Lucas fuel treatment at every fill up. Does fuel treatment need to be used at every fill up and which kind is best and how much if this is true. (2nd dumb newb question of the day).
wiredgeorge is offline
post #2 of 15 Old 03-25-2019, 02:54 PM
JustinOOO9's Avatar
Quoted: 1413 Post(s)
Garage
Feedback Score: 3 reviews
this gets heated quickly but the facts are MILLIONS OF DIESELS GO MILLIONS OF MILES without any fuel treatment just fine. With that being said I use diesel kleen a few times a year to make me feel good. I will say it helped fuel economy (ever so slightly) with winter blend diesels. Generally speaking the winter blend is designed to be less prone to gelling but sacrifices fuel economy etc. but, other than that my fuel filters looked exactly the same, idle, performance the same etc.
I use it maybe 3-4 times a year and maybe little more if on a road trip with not my usual fill ups.
Find a big brand like diesel kleen, optilube and do the research and try it. For me it wasn't nearly enough to justify adding every single tank but a few times sure.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is online now
post #3 of 15 Old 03-25-2019, 03:13 PM Thread Starter
Quoted: 3 Post(s)
I am a bike guy and an oil thread is one of the ways to get some silly going. Sorry but I had to ask because the PO insisted it was life or death to use this stuff every fill up. I did a google search and all the companies that make diesel fuel treatment swear you need to use it constantly. Well, you told me what I suspected.
post #4 of 15 Old 03-25-2019, 03:39 PM
kcoyner's Avatar
Quoted: 188 Post(s)
It's all about the advertisement with the miracle fluids and what you believe. I use a little Diesel Kleen once in a while.
k
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #5 of 15 Old 03-25-2019, 05:01 PM
G8orFord's Avatar
Quoted: 2402 Post(s)
Garage
The biggest advantage to using an additive is to increase lubricity and to pull any water in the fuel out of suspension. The newer ULS diesel has lost lubricity from the old style diesel we used to run. Making sure the water gets trapped by the separator and not getting through with the fuel is a bigger deal, IMO. I ran a ~70/30 mix of TCW3 ashless 2 cycle oil and Diesel Kleen gray bottle at about 8 oz. per tank in the old 6.0. If I missed a few tanks, I didn't worry about it.
I use Optilube Summer Blend in the 6.7 and pretty much have the same level of concern over missing a few tanks.
HP MACHINE likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #6 of 15 Old 03-28-2019, 02:52 PM
Quoted: 9 Post(s)
Optilube consistantly.....studies were done, this was near the top. I see 1.5 mpg and better running....about 8 oz in 36 gals....my enfine stays clean thru the turbos....i was a skeptic....but i think there is something to it now
Sent from my SM-G900V using Tapatalk
mohead1 is offline
post #7 of 15 Old 03-28-2019, 02:53 PM
Quoted: 9 Post(s)
Optilube consistantly.....studies were done, this was near the top. I see 1.5 mpg and better running....about 8 oz in 36 gals....my engine stays clean thru the turbos....i was a skeptic....but i think there is something to it now
mohead1 is offline
post #8 of 15 Old 04-12-2019, 02:13 PM
Hey George good to see a familiar name over on this forum. As for additives, I read the same research as Mohead1 did. I also run the Optilube in every tank an 4oz per fill up about 30 gal. I believe the suggested rate is 1oz per 10 gallon. I think that the additive discussion here could be like the weight or tire discussion on the Keystone forum.
Sent from my LG-LS993 using Tapatalk
5J's is offline
post #9 of 15 Old 04-12-2019, 02:53 PM
Quoted: 9 Post(s)
Cool....i swear the opti-lube gave me at least 1.5 mpg on normal daily, and 1 mpg on towing with a 15k lb load...truck runs good...i gotta really watch cuz its rollin on but my temps are headed for 800+ if not careful...i like around 72 mph at 780 deg F
mohead1 is offline
post #10 of 15 Old 04-13-2019, 05:51 AM
ChrisSki's Avatar
Quoted: 490 Post(s)
Only time I will use a fuel additive is if I'm not going to be driving for a long time and I will put Diesel Stabil in it. I have used Diesel Kleen and Lucas Oil, but I never saw any real improvement. Sometimes I think I saw 1 MPG netter, but I think that's because I babied it. I have Rev X for the oil, but haven't been adding that. I added for siction, and in sunny AZ, never gets cold enough for stiction to be a problem.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
Similar Threads
Thread Thread Starter Forum Replies Last Post
Water in fuel! pdsw60 6.7 Motor Problems (2011-2016) 69 08-13-2018 06:11 PM
No fuel in fuel bowl dpbaker General 6.0L Discussion 1 05-11-2018 12:44 PM
Fuel treatment TeamSvenske 94-98 7.3L Problem Forum 6 04-26-2017 04:26 PM
Potential fuel filter problem? OH IT'S KINO 6.7 Problems Forum (2011-2016) 6 09-21-2016 08:16 AM
Injection System Explanation mschn99 Dieselmann's Links 0 12-12-2006 08:29 AM
