Trans fluid compatibility - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 22 Old 03-04-2019, 08:58 AM Thread Starter
jrh
Quoted: 15 Post(s)
A shop did a fluid flush on the trans before I bought it - they said they used "BG" full syn fluid
https://www.bgprod.com/catalog/trans...synthetic-atf/
I've been wanting to do a drain/refill and swap over to the 08+ trans pan and filter at the same time. I bought a bunch of Mercon SP.
Can I mix them? Is one better than the other?
jrh is offline
post #2 of 22 Old 03-04-2019, 09:49 AM
JustinOOO9's Avatar
Quoted: 1678 Post(s)
Garage
Feedback Score: 3 reviews
never ever heard of the BG fluid. and The mercon is full synthetic and you already have it. Just use it as its a proven fluid for the truck. I used Mercon SP and LV during the transition years for the ford recommended fluid and no issues. I wouldn't use something like BG personally since the Mercon is a proven quality fluid. AND you already have it...
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #3 of 22 Old 03-04-2019, 10:26 AM
DesertDiesel's Avatar
Quoted: 71 Post(s)
How long have you been running the SP and LV? I did a good amount of research when I changed mine and the majority consensus was the 4r100 required Mercon V only. Even though I read all about the Ford transition to SP and LV.
JARED
2000 7.3 4x4 CC, 210,000 miles.
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
DesertDiesel is offline
post #4 of 22 Old 03-04-2019, 10:34 AM
Quoted: 71 Post(s)
JARED
Even though I had already purchased SP then switched my thinking to Mercon V. I still have 9 quarts of SP sitting in the garage. I've been using it to top off my daughters '98 Camry powersteering because of a leak. LOL
JARED
post #5 of 22 Old 03-04-2019, 11:05 AM
Quoted: 461 Post(s)
JARED
Who is running the 4R100? I assumed the OP is running a 6.0L.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #6 of 22 Old 03-04-2019, 11:18 AM
Quoted: 71 Post(s)
Assuming Justin is? My intent is not to hijack the thread though. Just a question and short comment.
JARED
post #7 of 22 Old 03-04-2019, 11:31 AM
Quoted: 461 Post(s)
JARED
Gotcha! I wasn't jumping on you for a hijack, I just wasn't following the reason for the question!
Mark
No-start thread:
bismic is offline
post #8 of 22 Old 03-04-2019, 12:01 PM
Quoted: 71 Post(s)
No worries!!
JARED
post #9 of 22 Old 03-04-2019, 01:32 PM
JustinOOO9's Avatar
Garage
JARED
I run dexmerc in my 4r100 behind the 7.3l I drive. I ran the mercon lv/sp in the 5r100 when I had my 6.0ls. had them over 30k miles after service and no issues. had a shift solenoid I needed to replace but that was super quick and easy.
Personally I wouldn't run mercon V in the 4r100s do your research and come to your own conclusion though. The Valvoline dexmerc is available at walmart and technically the closest to the original mercon the e4rods and 4r100s came with so I went with that for price,availabity and being closest to oringal spec fluid etc.
post #10 of 22 Old 03-04-2019, 05:24 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 609 Post(s)
Feedback Score: 11 reviews
Probably another companies name for their version of sp or lv.
Drain and fill like normal.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
97 f350 started pouring trans fluid PigpenF350 94-98 7.3 Trannie Problems 1 02-25-2019 04:44 AM
New 5R110 Transmission Venting Fluid sherich 6.0L Ford Excursion Discussion 24 05-04-2018 04:10 PM
Radiator mixed coolant and trans fluid Dynomite 6.0 Trannie problems 2 07-11-2017 05:06 AM
Trans puking fluid exorcist style Jbland20229 94-98 7.3 Trannie Problems 7 05-04-2017 08:41 AM
poor mans trans fluid change JustinOOO9 99-03 7.3L General Discussion 28 10-25-2016 11:46 AM
