Removing starter on a 6.0 - Ford Powerstroke Diesel Forum
 20Likes
post #1 of 18 Old 01-10-2019, 02:24 PM Thread Starter
Quoted: 2 Post(s)
Cannot find the third bolt on this 2004 6.0. whats happening is the truck barley turns over. Batteries are good. just dont know if it is the starter or not.
sirweldalot is offline
post #2 of 18 Old 01-10-2019, 02:41 PM
california deplorable
john galt's Avatar
Quoted: 3124 Post(s)
not sure if i have a pic of bolt locatioin but it is up behind the starter and a PITA to get at.
could also be your grounds the stock wires are kinda cheap but if yhou replace the starter get a 6.4 starter spins up much faster and while it didnt really shorten my start time any it didnt need to.
if i can find a pic or good link i will add it to this post
Jake6.0 and sirweldalot like this.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
The Following 2 Users Say Thank You to john galt For This Useful Post:
sirweldalot (01-10-2019)
post #3 of 18 Old 01-10-2019, 02:52 PM
john galt's Avatar
i will just add to another post...it's easier
Name:	ford 6.0 starter diagram.jpg
partyman97_3 likes this.
I like mead
post #4 of 18 Old 01-10-2019, 04:43 PM
Quoted: 373 Post(s)
Garage
If you have any rings....Don't forget to take them off your fingers
ZMANN, john galt, Jake6.0 and 1 others like this.
New 2019 F350 CCLB Platinum
Last Truck 2006 F350 CCLB KR
I'm out old man. I'm just a pecker-wood who lives in the woods with too many guns. Ya happy?"
BridgerMT is offline
The Following User Says Thank You to BridgerMT For This Useful Post:
john galt (01-11-2019)
post #5 of 18 Old 01-10-2019, 05:57 PM
Jake6.0's Avatar
Quoted: 117 Post(s)
Garage
This starter is such a PIA that after looking for the longest time I found whoever put mine on didn't bother with the top bolt, which is hidden up and over the top of the starter as you look at it from below. I tried for the longest time from a creeper, finally found that you can see where the bolt goes from under the wheel well towards the back there's a little gap between the fender tub and the frame. I put my socket on a long extension, folded a piece of paper towel over the bolt head and stuck it on the socket. Set a light shining from behind and you can see through the crack, guide the bolt to the hole and give it a finger spin, then crawl back under and attach the ratchet and finish. If there's an easier way anybody knows I'd love to know it too cause it was a b!tch, my elbow is still recovering.
john galt and sirweldalot like this.
Jake6.0 is offline
post #6 of 18 Old 01-10-2019, 06:03 PM
ChrisSki's Avatar
Quoted: 554 Post(s)
I think I used a couple of extensions about 8" long and a swivel socket to get in there. When I fool with that area, I disconnect both batteries. I caused quite the spark show when I forgot. Luckily it was a screwdriver and I did not arc weld my ring. There's some good YouTube videos if you search.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
The Following 2 Users Say Thank You to ChrisSki For This Useful Post:
post #7 of 18 Old 01-10-2019, 11:47 PM Thread Starter
Quoted: 2 Post(s)
it is possibly the starter?I am getting 850 at both batteries according to the auto parts house.I also cleaned the connections very well. So,I should find body ground straps and clean those as well?
post #8 of 18 Old 01-11-2019, 04:58 AM
ChrisSki's Avatar
Quoted: 554 Post(s)
It could be the starter. You can either trace and clean the grounds as suggested or pull the starter and bring it to the same auto parts store to be tested. As an alternate, you can tap it lightly with a hammer, and if it starts working, its the starter. I did this to mine and it would work for a little and go bad again, so its not a permanent fix. I'm also not positive the normal parts stores test our batteries to the loads our trucks put on them, but to what a normal small car sees.
john galt likes this.
Ravelco
Good 6.0 Reading:
post #9 of 18 Old 01-11-2019, 05:02 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 600 Post(s)
Feedback Score: 11 reviews
probably the cables. do you have a DVOM? you need to OHM out the cables.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #10 of 18 Old 01-11-2019, 07:02 AM
ZMANN's Avatar
Quoted: 3909 Post(s)
slow crank can also be a locked AC compressor or motor issue to name a couple
i would do a 6.4 starter swap that way even if it is not the starter the wrenching you did went for an upgrade vs misdiagnosis LOL
bismic and john galt like this.
6.0 flush pdf
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
