Good shop to 'bulletproof' or 'dealerproof' my 6.0 - Page 2 - Ford Powerstroke Diesel Forum
 5Likes
post #11 of 14 Old 12-04-2018, 06:00 PM Thread Starter
Quoted: 2 Post(s)
Jokester,
I live in Medford.
Bradlybones is offline
post #12 of 14 Old 12-04-2018, 06:09 PM Thread Starter
Quoted: 2 Post(s)
Might be worth troubleshooting before you spend big bucks.
Yeah, I did but nothing showed up on the reader. I only happened going over the mountains.
But I want to get it done anyway, I like my vehicles to be trustworthy and hate taking risks I don't need to take. I'll be asking a lot from the truck so I want it to be in good shape.
The tranny is in great shape as is the 4 W drive system. I'm having the front end tightend up. Maybe I can arrange it to go to Mesa during Spring Training and watch some baseball while the truck is being worked on. That's an idea.
Bradlybones
post #13 of 14 Old 12-04-2018, 07:31 PM
Quoted: 515 Post(s)
Originally Posted by ChrisSki View Post
I'm guessing the wrench was the oil cooler, but you can't know for sure without a monitor and watch ECT and EOT. I don't know what trips it, but I thing its 25° for 45 minutes. Just make sure you put some thought into what goes into bulletproofing, it goes from $1k for a stud only job (terrible idea) to an engine rebuild in excess of $10k, probably excessive.
It could be as simple as a temperature sensor. Could be an EBP sensor or a sticking turbo. Could even be simply a dirty EGR valve.
A 15 degree differential trips it (for a given speed and load condition that lasts for a certain amount of time). So does an overboost. So does a FICM low voltage or even a vehicle low voltage.
OP - I am sure we could help you troubleshoot it, but it sounds like your mind is made up.
Best of luck to you.
jokester00 likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #14 of 14 Old 12-04-2018, 08:36 PM
jokester00's Avatar
Quoted: 534 Post(s)
Garage
Agreed with @bismic . I think if you pulled the codes and posted them on here, along with your symptoms your having, we could help you out a bit, and probably save you some coin. I know the guys on here have saved me hundreds, if not thousands of $$'s in repairs and troubleshooting.
If you're dead set on taking it to someone, see the BPD preferred installer locations in the link below. There are 2 or 3 right around your area.
https://www.bulletproofdiesel.com/Articles.asp?ID=373
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
