2006 F350 6.0 Dually Build (My wife won't look at my pics anymore) - Page 8 - Ford Powerstroke Diesel Forum
 160Likes
post #71 of 133 Old 11-06-2018, 07:56 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
Originally Posted by Jake6.0 View Post
Today got a few things accomplished. Build budget is not depleted, but to the point I'm watching. I figured what's the worst thing that could happen if my locking hubs went bad. Stuck in 2wd? IDK but I wasn't real impressed with the OEM ones TBH, they don't look that robust. I want Warn but these "Tom Auto" ones look at least as good as the ford ones.
Crown jewel of the week so far is the Red Head "Extreme Duty" steering gear. The stock gear is an impressive piece of hardware, but this thing looks and weighs like a beast. Hope it'll pay off when the wife is looking over her shoulder backing the rv that we don't have yet into a spot.
Ford used Warn hubs on these trucks OEM. Someone correct me if Im wrong.
But regardless of my accuracy there, you have a lot of nice items there giving me a solid case of envy. Looking good bud.
Jake6.0 likes this.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #72 of 133 Old 11-08-2018, 07:18 PM Thread Starter
Jake6.0's Avatar
Quoted: 117 Post(s)
Garage
Huge shoutout to Oliver @ODAWG714 thanks for your help!
Spent the past 3 days wrestling with my new ODawgs Stage2 ported intake. Being new at this at first I thought it was the O-ring gasket not compressing, I tightened it a bit past recced torque and stopped when I saw there was still a big gap at the intake manifold. Searched high & low and finally found a clearance issue at the top of the coolant dome on the top oil cooler cover. Not sure if it's because of the new heads, new oil cooler cover or the intake, or all 3 but it didn't quite fit.
Called ODawgs and talked with Oliver who helped me with a resolution. The resolution scared the crap out of me, but he assured me they wouldn't void my warranty so I went for it. He said the casting is 3/16" there so grind yourself some clearance. This is my new $900 intake, but as the mrs. says, devil hates a coward so I fired up the die grinder..
Ground a little at a time and smeared the coolant dome with "liquid chalk", checked for fit, ground off where it touched and repeat X10. Now it fits! Thanks again Oliver!
ID:	710473   Click image for larger version
ID:	710475   Click image for larger version
ID:	710477   Click image for larger version
ID:	710479   Click image for larger version
Jake6.0 is offline
post #73 of 133 Old 11-08-2018, 07:29 PM Thread Starter
Jake6.0's Avatar
Quoted: 117 Post(s)
Garage
Another big shoutout to Steve @Mishimoto !
I bought the MMRAD-F2D-03 radiator a couple months ago. I found out (only because I joined this forum) that there is a problem with that rad in exactly the application I'm doing this build for (towing heavy in the summer),and they have a replacement thicker walled unit MMRAD-F2D-60. Initially I was told if mine fails I could exchange it. I pointed out that it was almost guaranteed to fail in my application, and I didn't want it to be halfway up a mountain w/ the wife and puppy and trailer then deciding to take a dump. Steve said he'd run it past customer support. They called me today and said just send the -03 back and they'll send out a new one, I only cover shipping. That is what I call standing behind your product! Mishi will get all my cooling business from now on. Thanks Steve!
Jake6.0 is offline
post #74 of 133 Old 11-09-2018, 02:24 AM
Motor Head.
robertc68's Avatar
Quoted: 91 Post(s)
I would still investigate this,some that tow are still having issues with the newer ones too.
Jake6.0 likes this.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.KC 2R turbo,2011 rear leafs,13 tailgate,flight fab trac bars. Power/folding/Extend mirrors.
robertc68 is offline
post #75 of 133 Old 11-09-2018, 02:28 AM
Quoted: 790 Post(s)
Just keep a spare in the truck ... problem solved
Sent from my iPhone using Tapatalk
mhatlen and Jake6.0 like this.
2007 F250 Lariat Outlaw
174k
Stock Motor
5" MBRP Catback
Boudah is offline
post #76 of 133 Old 11-09-2018, 05:25 AM
Supporting Vendor
Mishimoto's Avatar
Quoted: 74 Post(s)
Thank you! I'm glad we could get everything worked out for you!
I think I've only seen one customer reporting towing issues with our -60 rad, and I believe they were having overheating issues before installing. If anybody else is having issues with the -60 rad, please feel free to shoot me a message or get a hold of our Customer Service team and we'll work to figure out what's going on.
Thanks!
-Steve
Jake6.0 likes this.
Mishimoto is offline
post #77 of 133 Old 11-09-2018, 12:34 PM Thread Starter
Jake6.0's Avatar
Quoted: 117 Post(s)
Garage
It's possible to have issues with almost anything, the important part is what kind of customer service you get if it happens. I'll be sure to keep my eye on the rad (and all my parts), but I'm more than satisfied at this point.
Jake6.0 is offline
post #78 of 133 Old 11-09-2018, 06:21 PM
BTL
BTL's Avatar
Quoted: 196 Post(s)
My garage is always closed up so I do not have too much of a worry about one getting in. I, like Mhatlan can not stand opossums. Flea ridden disease carrying giant rat sloths! Then again I do not like raccoons much either. Damn things with their little thieving hands can take the locking handles off the garbage can lid. I had one at a house years ago spread strawberry pie all over my back deck. Hell of a mess to clean up. Had another one get in to my smoker and steel my smoked trout. I may have been a little altered the next time I used the smoker because somehow I thought it was a smart idea to put in in my 1978 Chevy truck bed and close the shell to prevent the little robber from striking again. The goods in my smoker were safe from the raccoon but my shell smelled like smoked venison jerky forever afterward.
BTL
09Busaman and Jake6.0 like this.
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4 SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8 draw tube
BTL is offline
post #79 of 133 Old 11-10-2018, 04:13 PM Thread Starter
Jake6.0's Avatar
Quoted: 117 Post(s)
Garage
Today I FINALLY got to unbox and install my new KC Stage1 turbo. It's parts porn if there ever was! Getting closer.....
ID:	710529   Click image for larger version
ID:	710531   Click image for larger version
BTL likes this.
Jake6.0 is offline
post #80 of 133 Old 11-10-2018, 05:19 PM
Sock Puppet's Avatar
Quoted: 559 Post(s)
Yeah...you should have posted a 'Porn Warning' before that last set of pics.
Jake6.0 and CasaDeHouse like this.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
