What to do with a 2003 - Page 3 - Ford Powerstroke Diesel Forum
 95Likes
post #21 of 56 Old 09-16-2018, 06:44 PM
DieselDC
DieselDC's Avatar
Quoted: 676 Post(s)
New heads as suggest. + whatever everyone suggested and while you’re there, new lifters and push rods. It’s a free truck - throw some
Money at it and it will be one solid truck - especially if 5k miles a year!
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
DieselDC is offline
post #22 of 56 Old 09-16-2018, 07:23 PM
Master_Chase's Avatar
Quoted: 515 Post(s)
Originally Posted by s10mike View Post
cummins 12valve swap. cheap and easy
Originally Posted by G8orFord View Post
Yeah, cheap and easy is relative. There's a couple of guys on here that have done it recently as well. @junior125 @Master_Chase
Originally Posted by junior125 View Post
if you were to consider doing a 12 valve swap, I wouldn't even consider it if you're paying someone else to do it I wouldn't bother, it can be pretty time consuming especially the first time around
Can confirm not cheap at all to swap the engine and really not that easy either of course once I finish this one it will probably be a lot quicker next time around.
I'll add to @junior125 post and say I can't see doing all the work to swap a Cummins into a super duty. It's a lot of time and cash for something that can be replaced easy enough, don't like the 6.0 buy an older 7.3 or newer 6.7, hate it so much not to want another ford buy Ram or GM.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #23 of 56 Old 09-16-2018, 11:10 PM
repalmer's Avatar
Quoted: 438 Post(s)
Or you can just sell it cheap...to me
repalmer is offline
post #24 of 56 Old 09-17-2018, 06:56 AM
SparkyF250's Avatar
Quoted: 3016 Post(s)
Garage
This thing has yet to be properly diagnosed. And we're throwing new engines or heads at it!
Pressure test the cooling system first. Is there any signs of coolant puking from the cap on the degas bottle? Have you checked the EGR valve?
Pull the EGR valve and see if it's wet or dry. Put a T in the 3/8"line going to the degas and plumb in a pressure gauge (run it up by the wipers or side mirror where you can see it) and get it up to temp, release the pressure (carefully) then watch the gauge on a couple WOT runs, if it stays under 15 psi and doesn't fluctuate with the throttle then look for a different problem.
Sounds like the shops that it's been to must have used these...
And yes, like G8tor and Bill said, no problem with 200K as long as the truck has been maintained
junior125, john galt and 6.4man like this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
1991 F350 4x4, 7.3 IDI Flatbed, 5 speed...sold
2008 F250 SCLB 6.4...Sold
SparkyF250 is offline
post #25 of 56 Old 09-17-2018, 06:19 PM
kcoyner's Avatar
Quoted: 190 Post(s)
a buddy of mine did it, and although i dont know what it cost him [had an engine already], he said it was the easiest enginge swap over hes ever done. that ended his 6liter problems
The defense rests.
k
bismic and Sock Puppet like this.
2005 F-350 Lariat DRW. WAAAAYYYY to much for 500 character limit
kcoyner is offline
post #26 of 56 Old 09-17-2018, 06:52 PM
california deplorable
john galt's Avatar
Quoted: 3026 Post(s)
if you can get new kdd heads studs a new shop while yohu are in there change out the oil cooler get a bpd water pump egr cooler or delete the egr and run it.
with a monitor etc
bismic likes this.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #27 of 56 Old 09-17-2018, 07:11 PM
Quoted: 247 Post(s)
I believe that the OP just wants us to confirm a new engine is needed (hope I am wrong!) .....
Unfortunate too, because it is so easy to test some of the big things yourself.
So many shops bring in a lot of money off of the 6.0L trucks, due solely to their "reputation", which in turn continues to add to the bad reputation. Lots of people have been taken to the cleaners unnecessarily - when they take the truck in without being prepared and educated.
SparkyF250 and jdougn like this.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Bilsteinshocks; BPD EGR cooler;One-piece HPOP fitting;BPDWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #28 of 56 Old 09-22-2018, 06:13 PM
Quoted: 29 Post(s)
Originally Posted by kcoyner View Post
The defense rests.
k
best part... he knows its reliable. not a ticking timebomb moneypit. thats priceless
s10mike is offline
post #29 of 56 Old 09-22-2018, 06:39 PM
Quoted: 247 Post(s)
My 206k mile ticking time bomb moneypit has been great to me (no issues) - THAT is the BEST thing!
SparkyF250 and 6.4man like this.
Mark
bismic is offline
post #30 of 56 Old 09-22-2018, 07:01 PM
Quoted: 29 Post(s)
Sweet. That's a ton of miles.
s10mike is offline
