New (to me) '05 F350 Looking for Advice - Page 2 - Ford Powerstroke Diesel Forum
 7Likes
post #11 of 27 Old 09-12-2018, 02:28 PM
Quoted: 327 Post(s)
With those temperatures, I would only flush w/ distilled water. Don't think a chemical flush is necessary.
bismic is offline
post #12 of 27 Old 09-12-2018, 02:40 PM Thread Starter
AudioEng03's Avatar
Quoted: 16 Post(s)
Garage
I was kinda thinking the same thing. It seems to be flowing well, so I don't want to take the chance of messing something up getting crazy with the flush. Hopefully a couple of fill and drains with distilled water will get all of that Motorcraft Gold out of there.
AudioEng03 is offline
post #13 of 27 Old 09-12-2018, 04:04 PM
Quoted: 327 Post(s)
You will probably need more than a couple, even if you open the block drains and take off the lower radiator hose.
bismic is offline
post #14 of 27 Old 09-12-2018, 04:36 PM
Sock Puppet's Avatar
Quoted: 557 Post(s)
Here is something to consider regarding the flush. My ECT/OT numbers were very close to yours. I decided not to use VC9 or Cascade to clean the system. I flushed it like crazy with a garden hose, pulled both block drains multiple times, ran it a bunch without the thermostat in. I then flushed it a couple of times with distilled water, then topped off with Rotella ELC. That was at least 10K miles ago and my temps have not changed at all.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #15 of 27 Old 09-12-2018, 04:37 PM
Quoted: 557 Post(s)
Looks like @bismic beat me too it.
The Following User Says Thank You to Sock Puppet For This Useful Post:
Bilko60 (09-13-2018)
post #16 of 27 Old 09-12-2018, 05:13 PM Thread Starter
AudioEng03's Avatar
Quoted: 16 Post(s)
Garage
You're probably right. But, one can hope, right?
post #17 of 27 Old 09-12-2018, 06:41 PM
Quoted: 327 Post(s)
LOL, I know how much is retained in the engine after you open all the drains. You can get maybe 4 gallons out and it holds 7. Straightforward math after that!
After 2 drain and fills, you will still have 1.3 gallons of the old stuff in, and that is if it is well mixed after the first drain and fill.
The garden hose continuous flush works better to get the old coolant out, but you still need to flush 3 times (IMO) to get the hose water out.
rtr688 likes this.
bismic is offline
post #18 of 27 Old 09-13-2018, 04:03 PM Thread Starter
AudioEng03's Avatar
Quoted: 16 Post(s)
Garage
I got the EAS Fuel pressure and EGT sensors for my CS2. The install on the fuel pressure sensor seems pretty straightforward. I already ordered the thread adapter and 45* elbow from Glow Shift.
I am not as confident about installing the EGT probe. Do any of you have pictures of exactly where you installed it? Or perhaps any tips or tricks I should know prior to drilling into my exhaust manifold all willy nilly?
post #19 of 27 Old 09-13-2018, 04:43 PM
G8orFord's Avatar
Quoted: 2525 Post(s)
Garage
It's just a hole, what could go wrong? LOL
Put a magnet by the spot you drill to catch any shavings that might get into the manifold. When you're done, get a shop vac to the hole and and remove the magnet to pull those shavings out. Do the same when you tap the hole. That's about it.
AudioEng03 likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #20 of 27 Old 09-13-2018, 06:22 PM
Quoted: 557 Post(s)
I don't have any pics of my EGT location, but it's on the rear drivers side manifold, on the bottom. I used the Glowshift adapter on my fuel press. and it's worked just fine. Here is how I plumbed mine (disregard the extension and socket on the t-stat housing):
