KC Stage 2 Turbo Problem... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 08-13-2018, 06:31 PM Thread Starter
gitnmybelly's Avatar
Quoted: 6 Post(s)
Garage
Send a message via AIM to gitnmybelly Send a message via Yahoo to gitnmybelly Send a message via Skype™ to gitnmybelly
Unhappy KC Stage 2 Turbo Problem...
... I am heading to Gainesville (stopping off in Williston) from Orlando today. I am pulling a dual axle lawn trailer with only a zero turn on it. I get on I75 and get into some 3 hour traffic a lot of stand still and under 5 mph. I get to Ocala Hwy 200 and notice that something sounds and feels funny when I give it gas.
I get out in williston and when I shut of the truck i dont hear the turbo spinning like I normally do.
When I get back to orlando, I am going to pull the turbo and send back to KC for inspection.
Nothing on my SCT seems off still.
Anyone have an idea or have had any issues with their Stage 2 KC Turbo?
gitnmybelly is offline
post #2 of 13 Old 08-17-2018, 07:57 AM
Quoted: 247 Post(s)
Do you always "pre-oil" the turbo before you crank the engine?
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Bilsteinshocks; BPD EGR cooler;One-piece HPOP fitting;BPDWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #3 of 13 Old 08-17-2018, 11:05 AM Thread Starter
Quoted: 6 Post(s)
Garage
that could be my problem.... how do I "pre-oil" the turbo?
post #4 of 13 Old 08-20-2018, 10:09 AM
Quoted: 14 Post(s)
Standard journal bearing S2, or do you have the S2R?
2005 Eddie Bauer Excursion 4x4
Kill Diesel O-Ring Heads
KC 2R Turbo - Replaced with S3
190/30 Warren Injectors
ODAWG III Intake Manifold
AirDog II
Driven Diesel Regulated Return w/ Bowl Delete
BPD Air to Oil Cooler w/ Bypass Filter
Colt Stage II Cam
EGR Delete
Coolant Filter
Mishimoto Intercooler
Mishimoto Radiator
S&B Intake Elbow
S&B Intake w/o Box Lid - Removed for No Limit
4" Turbo Back Pipe
SPD Tune
CTS Monitor
6" Lift
22x12 AF Fallout
35x12.5 Toyos
gpern83 is offline
post #5 of 13 Old 08-21-2018, 07:28 AM Thread Starter
Quoted: 6 Post(s)
Garage
KC S2R. Are the lines typically supplied by the Turbo companies? or do I need to purchase that separate?
post #6 of 13 Old 08-21-2018, 07:40 AM
Fummins Mod
junior125's Avatar
Quoted: 2148 Post(s)
Garage
merged threads
@peixinho would be the gentleman you should be in contact with
jokester00 likes this.
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #7 of 13 Old 08-21-2018, 08:53 AM
ZMANN's Avatar
Quoted: 3781 Post(s)
when you merge a thread it can sure make someone's questions look ridiculous
when I had asked about the MFG of the turbo that thread had no mention of KC turbo
6.0 flush pdf
ZMANN is offline
post #8 of 13 Old 08-21-2018, 09:42 AM
Quoted: 774 Post(s)
The feed line are a ford factory part. But that shouldn’t matter.
Maybe the bearings too a dump if it’s the S2R
Sent from my iPhone using Tapatalk
2007 F250 Lariat Outlaw
174k
Stock Motor
5" MBRP Catback
Boudah is offline
post #9 of 13 Old 08-21-2018, 11:28 AM
jmeaby's Avatar
Quoted: 65 Post(s)
Be interested to see what Charlie says. Always appreciate his input
04 f250 cc sb.
colt cam stage 2, kill devil diesel heads, stage 1 pushrods, odawg s3r, bd manifolds,odawg y pipe, 4 inch turbo back ss magnaflow exhaust, CSF 6028 intercooler, mishimoto radiator, billet turbo wheel, 05 style headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP and IDP, BDS Dual rear add a leaf, Firestone ride rite airbags, rough country leveling kit on 35s, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
check me out on youtube and follow the build at 6.0 bros
jmeaby is offline
post #10 of 13 Old 08-21-2018, 01:55 PM
peixinho's Avatar
Quoted: 341 Post(s)
Hey guys... the best way to get help if you are having issues with a KC Turbo is to contact us directly. Sadly I am not on the forums all day every day.
Have you contacted KC Turbos yet?
[email protected]
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
