placement of EGT probe? - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 14 Old 07-24-2018, 02:27 PM Thread Starter
mrh1282's Avatar
Quoted: 88 Post(s)
I got my EGT probe in last week and I would like to install it before this weekend, but having hard time finding video or pics on where to install it. I see there was a sticky on it but no pictures anymore. I know it goes in drivers side manifold right on the bend. If you have some pictures that you can share i would appreciate it. I would feel a little better before i put the hole in the wrong spot.
Thank you
2005 F250 CCSB 4x4: Edge insight CTS2 with EAS EGT probe, SCT X4 with Gearhead tunes, Blue spring mod, XDP coolant filter, Cat ELC, High idle mod, 6.4 starter, Fumoto drain valves for coolant and oil, Harpoon mod, 08+ towing mirrors, transmission pan and filter, tailgate and tail lights, 2016 rear leaf springs, Rancho RS9000XL shocks. More to come.....
mrh1282 is offline
post #2 of 14 Old 07-24-2018, 02:32 PM
Fummins Mod
junior125's Avatar
Quoted: 2222 Post(s)
Garage
Here ya go
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #3 of 14 Old 07-24-2018, 03:20 PM
ZMANN's Avatar
Quoted: 3962 Post(s)
@mrh1282
Gauge Installations at DieselManor - 2003-2007 6.0L Ford Powerstroke
remember when tapping the hole not to run an NPT tap too far since they are tapered it is easy to overdo it and then the sender won't tighten up before it gets to the end of it's threads
6.0 flush pdf
ZMANN is online now
post #4 of 14 Old 07-24-2018, 05:07 PM
ChrisSki's Avatar
Quoted: 575 Post(s)
The Driver Side by the Up Pipe as pictured is the same place my BD Exhaust Gas Manifold came pre-drilled.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #5 of 14 Old 07-24-2018, 10:26 PM
BTL
BTL's Avatar
Quoted: 202 Post(s)
I placed a couple magnets next to the drill bit and it collected all of the shavings while drilling. Much better than having them fall all over your face.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4” SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8” draw tube
BTL is offline
post #6 of 14 Old 07-24-2018, 11:02 PM Thread Starter
mrh1282's Avatar
Quoted: 88 Post(s)
BTL
Smart. I was also going to hold the shop vac while doing it too. But I like the magnet idea.
Sent from my iPhone using Tapatalk Pro
mrh1282 is offline
post #7 of 14 Old 07-25-2018, 03:00 AM
BTL
BTL's Avatar
Quoted: 202 Post(s)
The magnets worked perfectly for me, not a shaving escaped their magic. It is a little time consuming getting all of the metal dust off of the magnets when you are finished drilling for obvious reasons.
BTL
281,500mi
ARP Head studs,
BTL is offline
post #8 of 14 Old 07-25-2018, 06:45 AM
G8orFord's Avatar
Quoted: 2567 Post(s)
Garage
BTL
Wrap them in plastic first.
BTL likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #9 of 14 Old 07-25-2018, 02:14 PM
BTL
BTL's Avatar
Quoted: 202 Post(s)
Always someone more clever than I am.....perfect solution.
BTL
Jokersace likes this.
281,500mi
ARP Head studs,
BTL is offline
post #10 of 14 Old 07-25-2018, 02:21 PM
BTL
BTL's Avatar
Quoted: 202 Post(s)
“He said smugly”
BTL
281,500mi
ARP Head studs,
BTL is offline
