New?? Delo 400 XSP 5w-40 Synthetic - Page 3 - Ford Powerstroke Diesel Forum
 24Likes
post #21 of 38 Old 06-23-2018, 06:21 AM
Love all, Trust a Few...
LoxDiesel's Avatar
Location: If you go West and hit sugar cane come back a bit
Quoted: 1101 Post(s)
TDT?
Sent from my iPhone using Tapatalk
@loxdce
LoxDiesel is offline
post #22 of 38 Old 06-23-2018, 06:29 AM Thread Starter
G8orFord's Avatar
Quoted: 2600 Post(s)
Garage
https://express.google.com/u/0/produ...mpaign=8175035
Mobil 1 TDT
backhoebill likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #23 of 38 Old 06-23-2018, 07:42 AM
ars5147's Avatar
Quoted: 211 Post(s)
If anyone is interested
Get your mobil TDT while it's hot
https://apfco.com/secure/R9722W/Register
$10 off a gallon up to to 10 gallons
there's good rebates on their 15w40 too
john galt and jokester00 like this.
1997 F350 CCLB 7.3
2019 F350 CCSB 6.7 Lariat Sport
ars5147 is offline
The Following 4 Users Say Thank You to ars5147 For This Useful Post:
backhoebill (06-24-2018), john galt (06-23-2018), jokester00 (06-23-2018)
post #24 of 38 Old 06-23-2018, 10:12 PM
repalmer's Avatar
Quoted: 623 Post(s)
If anyone's still using it, Costco has Delo for $10 off per gallon.
Just got the sale flyer today
repalmer is offline
post #25 of 38 Old 06-24-2018, 07:31 AM
Quoted: 3 Post(s)
New Diesel Oil spec CK-4 not good if it also meets SN and SM.
This new spec requires below 1000ppm of phosphorus and zinc if the oil also is to meet SN and SM gasoline engine specs. Levels this low will wipe out the cams and rocker arms. Ford has already come against this spec citing excessive wear in powerstroke engines.
fordauthority.com/2017/03/ford-launches-new-oil-spec-for-6-7l-power-stroke-diesel/
So far Motorcraft oils have a new Ford specific spec which has higher levels, and early testing shows rotella is maintaining the higher levels and is rated CK-4 but not SN and SM.
All Delos and Delvac are below the 1000ppm level and meeting SN and SM also.
Rotella is not meeting SN and SM
see analysis here
pqiamerica.com/HDEO_Sample_Summary_Dec_2016.html
sixgear is offline
post #26 of 38 Old 06-24-2018, 08:33 AM
backhoebill's Avatar
Quoted: 1279 Post(s)
Send a message via Yahoo to backhoebill
$24.99 for Mobil1TDT at Oreilly.
Thanks @ars5147 for the rebate info
ars5147 likes this.
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #27 of 38 Old 06-24-2018, 08:33 AM
What’s up with Tapatalk double posting?!
ars5147 likes this.
post #28 of 38 Old 06-25-2018, 05:48 AM
"RLTW" Tennessee
F250_SUPER_4x4's Avatar
Quoted: 295 Post(s)
Originally Posted by jokester00 View Post
I hear ya there! That's a big reason why I switched to the Delo instead of continuing to run TDT - $27/gallon vs. $19 is quite a cost savings when you're buying 4 gallons!
-jokester
https://www.ruralking.com/oil-rotellat6-5w40-cj4-2-5gal
$20 a gallon, with no rebate or coupon.
1974 F100 RC 351W/C4
1978 F250 Super Cab 400/C6
2015 F250 PSD CC KR 408/6R140
2017 Harley Ultra Limited 107/6SPD
F250_SUPER_4x4 is offline
post #29 of 38 Old 06-25-2018, 05:55 AM
"RLTW" Tennessee
Quoted: 295 Post(s)
Originally Posted by G8orFord View Post
Is there a chart somewhere that tells you how much you need to add?
If using Rislone 3x concentrate ZDDP additive on wieght reduced diesels, the dosage rate is: Add one bottle to engine crankcase for every 5 quarts of oil capacity.
Caveats: If using CJ4 oil no need to add ZDDP but adding 1x bottle brings it to CH4 levels. Do not add ZDDP to any oil below CK4 if you are running a stock exhaust. Adding 1x bottle to CK4/SN brings it to CJ4 levels.
Qholic likes this.
post #30 of 38 Old 06-25-2018, 06:13 AM Thread Starter
G8orFord's Avatar
Garage
1 bottle per 5 quarts? So 3 bottles for an oil change? Just clarifying.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
